Mopar ECU replacement modules, who is better than stock?
#2767571
04/23/20 06:23 PM
04/23/20 06:23 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
I'm finishing up building a 1966 Dodge Coronet Deluxe two door sedan with a 440 motor and O.D. 4 speed, I added the wiring harness to make it have stock type Mopar electronic ignition, I had to use a stock black OEM ECU to get it running due to having several bad ECU in stock so I'm asking which brand and part number do you guys like and use in a deal like mine A friend told me about a unit he use to use from Car Quest but he can't remember the part number and the local Car Quest store closed up several years ago so no way t ask them now Thanks in advance
Re: Mopar ECU replacement modules, who is better than stoc?
[Re: Cab_Burge]
#2767600
04/23/20 08:07 PM
04/23/20 08:07 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I went round and round with my son on this. We tried a few OEM's we had here, worked a few days to 2 weeks at most. I made him a GM HEI modified ECU that looks 100% stock Mopar, it fried in 3 days. Put a Autozone unit in and it lasted 3 days. Finely got him to replace his 0.3 ohm Pertronix coil to a 1.4 ohm FAST coil and he has maybe 1 month and 3,000 miles on the replaced Autozone 'BLUE' 4 pin made by Wells
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: topside]
#2767744
04/24/20 07:22 AM
04/24/20 07:22 AM
Posts: 9,847 MI, usa
dvw
MI, usa
I was at Mopar Nats in the 90's with my blown 340. The orange box failed after it stormed at night. Ya back in day. Drove it from Detroit with no hood and no car cover. Put a junkyard box in it. Ran exactly the same Doug
[Re: topside]
#2767831
04/24/20 12:54 PM
04/24/20 12:54 PM
Cab_Burge
I went out to my shop and remembered ordering both Standard ignition LX101 and L100 ECU, there both on the shelf,man does it suck loosing your memory I don't like having to use both stock ballast resistors on the five pin ECU so I will probably switch the wiring harness over to use the four pin with no ballast resistor or one, what ever works per the instructions I'm going to try both of them to see how they compare to the stock black Mopar ECU, my understanding is that the stock ones have a built in rev limiter of 6000 RPM, which might be a good thing in a 4 sped car Thanks to all of you for the help
[Re: Cab_Burge]
#2767884
04/24/20 04:03 PM
04/24/20 04:03 PM
RapidRobert
iirc the LX101 is now made in china. the old one did have a good rep. I'd go with an HEI setup or a MP chrome box. As said get the right primary ohms coil
[Re: RapidRobert]
#2767988
04/24/20 11:41 PM
04/24/20 11:41 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
Cab, I've been running this one for a few years, car runs 11.0@121 with it. Made in USA from Jegs!
Part Number: 555-40805 JEGS 40805 $34.99 (9) Ships Today Lowest Price Guarantee HiRev 7500® Ignition Control Unit Modern Electronics with Mopar OEM Appearance Comparable to Mopar Chrome Ignition Control Unit 7,500 RPM Made in USA
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
