Help locating stock pitman arm for 93 w250 #2766144
04/19/20 10:39 PM
04/19/20 10:39 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I am in the process of ressurecting my 93 w250 12v that got hit by an inattentive driver. Unfortunately the pitman arm will need to be replaced. Any ideass on where I should begin my search? The usual ebay/google/cl searched left me empty handed. I see there are pitman arms spec'd for a 2" lift - can I use one on my stock truck?
Any thoughts much appreciated.
Re: Help locating stock pitman arm for 93 w250 [Re: Jeremiah] #2766159
04/19/20 11:37 PM
04/19/20 11:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked Rock Auto?
Re: Help locating stock pitman arm for 93 w250 [Re: stumpy] #2766164
04/20/20 12:02 AM
04/20/20 12:02 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Sure did. I ordered a new steering box and drag link. The pitman is not consideeed a wear part however they are often stuck on the sector shaft and have rui ned many quality pitman arm pullers. I cut a slit in mine about half way through parallel to the shaft in case I need to weld it up for reuse.
Re: Help locating stock pitman arm for 93 w250 [Re: Jeremiah] #2766168
04/20/20 12:48 AM
04/20/20 12:48 AM
Guitar Jones Offline
A 2" lift isn't much, I don't see why it wouldn't work.
Re: Help locating stock pitman arm for 93 w250 [Re: Guitar Jones] #2766215
04/20/20 09:16 AM
04/20/20 09:16 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thank you sir, I will order a 2" drop pitman and see if it works. This is the same truck I wrecked right after you helped me get the trans/OD shifting correctly. I think that was 4-5 years ago! Luckily it has been out of the weather the entire time so it's still mint (and now repaired : D )
Re: Help locating stock pitman arm for 93 w250 [Re: Jeremiah] #2766284
04/20/20 12:23 PM
04/20/20 12:23 PM
Cool, hope it all works out for you and you are welcome, I'm glad to help.
Re: Help locating stock pitman arm for 93 w250 [Re: Guitar Jones] #2767036
04/22/20 09:29 AM
04/22/20 09:29 AM
scratchnfotraction Offline
they make longer studs with a block that will raise the stock arm on the knuckles. lots less hassles and cheaper, skyjacker part IIRC.
Re: Help locating stock pitman arm for 93 w250 [Re: scratchnfotraction] #2767345
04/23/20 10:04 AM
04/23/20 10:04 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I have the steering knuckle block on my lifted truck w150 and it does a great job of correcting the geometry. Thanks for thinking of that!
Good news - I found a guy with a stock pitman so we are back in business. Much appreciate the help gentlemen!
