Tail light brighter on one side than the other #2764473
04/16/20 12:30 AM
04/16/20 12:30 AM
AndyF Offline OP
AndyF  Offline OP
My 1972 Duster has an interesting problem that I can't quite figure out. The passenger side tail lights (running and stop light) are brighter than the driver side. I swapped bulbs side to side and that didn't change anything. I checked the wiring with a voltmeter and they both read right at 12 volts. Both sides are operating properly, one filament comes on with the lights and then the second one comes on with the brakes. So everything checks out but the right side is definitely brighter than the left side. I looked at the lens to see if one side looked different than the other and I can't see any damage. They both look the same but it is almost as if the left side doesn't allow as much light to shine thru for some reason. Both sides appear to be original to the car, I don't think either one is a reproduction since they both have the Mopar part numbers and they both have some wear and tear on them like you would expect from 50 year old parts. Kind of stumped, anyone have an idea?
Re: Tail light brighter on one side than the other [Re: AndyF] #2764483
04/16/20 04:12 AM
04/16/20 04:12 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Andy, try cleaning the bulb socket and the mating area on the body. What you are discribing is a loose ground and the bulb is finding it ground thru the right sides bulbs, thats why they are extra bright too.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Tail light brighter on one side than the other [Re: Dave_J] #2764494
04/16/20 06:13 AM
04/16/20 06:13 AM
Port Huron, Michigan
MI_Custumz Online content
MI_Custumz  Online Content
You could also run something to touch to the assembly to ground it as a test to see if it's the ground. I did that to a few things before installing. I used auto wire with alligator clips on it. I also used that method to find a good ground for electric flashers that needed to be grounded to something. Easier because it gives you a length of wire to work with and you don't need to disassemble/assemble something all the way to get it to work.
Re: Tail light brighter on one side than the other [Re: MI_Custumz] #2764502
04/16/20 08:15 AM
04/16/20 08:15 AM
VA
dragon slayer Offline
VA
A voltage check without a load on the circuit can be misleading. If you check voltage with bulb in and on, does it read 12V? Chances are no. If it does, that would point to the lens. The measurement has to be on the terminals at the bulb socket if you can get to it. Otherwise you need to rig a jumper from the socket.
Re: Tail light brighter on one side than the other [Re: dragon slayer] #2764510
04/16/20 08:33 AM
04/16/20 08:33 AM
cmansell Offline
cmansell  Offline
So is the dim side correct or the bright side the goal? If you find the problem will they both be bright or the lesser?
Re: Tail light brighter on one side than the other [Re: cmansell] #2764527
04/16/20 09:57 AM
04/16/20 09:57 AM
Andrewh Offline
Andrewh  Offline
I found in my car the previous owner coated and painted a lot of stuff. So the grounds were poor for the tail lights, since they go through the body.
They make new pigtails for the lights with an extra tab on them for a ground wire.
I did that and it eliminated the ground issues.
but as said above you might want to test that out.
add an extra wire around the socket where it "holds" on to the tail light housing and give it a solid ground see if the dim light comes up to the other side.
Re: Tail light brighter on one side than the other [Re: AndyF] #2764536
04/16/20 10:14 AM
04/16/20 10:14 AM
Alberta
rustbuckett68 Offline
Alberta
Did you check the flutes on the inside of the lenses for dirt/grime? I'm sure the lenses come apart, outer red and inner reflectors. Also, sometimes the reflectors are faded or gunged up as well.
Re: Tail light brighter on one side than the other [Re: AndyF] #2764560
04/16/20 11:00 AM
04/16/20 11:00 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Some good ideas in here. I have found socket corrosion/dirt to cause this issue in the past. Might also verify the socket wiring isn't reversed and illuminating the brake filament instead of the running element.
Re: Tail light brighter on one side than the other [Re: AndyF] #2764562
04/16/20 11:07 AM
04/16/20 11:07 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
On my '69 B body I had that issue with the front parking lamps/turn signals.
I had to create some additional grounds to make the lights the same brightness.
Rich H.
Esse Quam Videri
Re: Tail light brighter on one side than the other [Re: ZIPPY] #2764566
04/16/20 11:15 AM
04/16/20 11:15 AM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
JUst went through this on my RR. Ground. Like mentioned above....make some leads and test
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Tail light brighter on one side than the other [Re: Dave_J] #2764580
04/16/20 11:56 AM
04/16/20 11:56 AM
AndyF Offline OP
AndyF  Offline OP
My taillight harness is brand new so there is no corrosion anywhere. All connections are bright and shiny. I can check voltage drop with the lights again but so far I haven't noticed any difference from side to side.
Re: Tail light brighter on one side than the other [Re: AndyF] #2764677
04/16/20 04:19 PM
04/16/20 04:19 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
OK, then like said above, use a true grounded wire and clamp it onto the bulb socket. If the bulb gets brighter it must be the housing not getting a good bite to tin. Or the housing is corrored where the bulb socket turns into.
If you were closer I could drop by. I'd give you a couple JP Popper clips with the Bed of Nails.
65 Formula S Cuda
Re: Tail light brighter on one side than the other [Re: Dave_J] #2764745
04/16/20 06:55 PM
04/16/20 06:55 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Fresh paint?
Re: Tail light brighter on one side than the other [Re: Dave_J] #2764747
04/16/20 06:57 PM
04/16/20 06:57 PM
What I'd do is with a length of wire with an alligator clip on one end & a long thin pointer on the other end, ground the alligator clip to a KNOWN good ground & take the lens off & reach in with the pointer & touch the bulb metal case & see if it brightens
Re: Tail light brighter on one side than the other [Re: Dave_J] #2765028
04/17/20 12:21 PM
04/17/20 12:21 PM
moparx Offline
moparx  Offline
dave, where does one buy those "popper" clips ?
TIA !
beer
Re: Tail light brighter on one side than the other [Re: moparx] #2765055
04/17/20 01:08 PM
04/17/20 01:08 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Quote
There was a thread somewhere recently and his issue turned out to be the inner socket disc in his new harness had been installed 180 degrees off.
Re: Tail light brighter on one side than the other [Re: Alaskan_TA] #2765097
04/17/20 03:01 PM
04/17/20 03:01 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted by Alaskan_TA
Quote
I saw that thread and I checked that. My bulbs are both operating correctly. Each side is on the correct element for run and brake. I also double checked the grounds and they are fine. Adding a second ground doesn't make any difference and the voltage drop to ground is very small. I'm pretty sure it is a problem with the lens.
Re: Tail light brighter on one side than the other [Re: AndyF] #2765101
04/17/20 03:08 PM
04/17/20 03:08 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Pull the sockets, run a jumper to ground if needed and compare bulb output. If they are different with the sockets out of the housing it;s the bulbs.
Re: Tail light brighter on one side than the other [Re: JMCFAN] #2765121
04/17/20 03:59 PM
04/17/20 03:59 PM
Andrewh Offline
Andrewh  Offline
Do one more test then.
with or with our sunglasses, pull the bulbs out with the extra ground wire on both sides.
see if they are both normal brightness to you without the housing.
