Re: Tail light brighter on one side than the other
[Re: AndyF]
#2764483
04/16/20 04:12 AM
04/16/20 04:12 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Andy, try cleaning the bulb socket and the mating area on the body. What you are discribing is a loose ground and the bulb is finding it ground thru the right sides bulbs, thats why they are extra bright too.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: AndyF]
#2764562
04/16/20 11:07 AM
04/16/20 11:07 AM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
On my '69 B body I had that issue with the front parking lamps/turn signals. I had to create some additional grounds to make the lights the same brightness.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2764566
04/16/20 11:15 AM
04/16/20 11:15 AM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
JUst went through this on my RR. Ground. Like mentioned above....make some leads and test
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: Dave_J]
#2764580
04/16/20 11:56 AM
04/16/20 11:56 AM
Posts: 31,002 Oregon
AndyF
Andy, try cleaning the bulb socket and the mating area on the body. What you are discribing is a loose ground and the bulb is finding it ground thru the right sides bulbs, thats why they are extra bright too. My taillight harness is brand new so there is no corrosion anywhere. All connections are bright and shiny. I can check voltage drop with the lights again but so far I haven't noticed any difference from side to side.
[Re: AndyF]
#2764677
04/16/20 04:19 PM
04/16/20 04:19 PM
Dave_J
Auburn WA
OK, then like said above, use a true grounded wire and clamp it onto the bulb socket. If the bulb gets brighter it must be the housing not getting a good bite to tin. Or the housing is corrored where the bulb socket turns into. If you were closer I could drop by. I'd give you a couple JP Popper clips with the Bed of Nails.
[Re: Dave_J]
#2764747
04/16/20 06:57 PM
04/16/20 06:57 PM
RapidRobert
What I'd do is with a length of wire with an alligator clip on one end & a long thin pointer on the other end, ground the alligator clip to a KNOWN good ground & take the lens off & reach in with the pointer & touch the bulb metal case & see if it brightens
[Re: moparx]
#2765055
04/17/20 01:08 PM
04/17/20 01:08 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
My taillight harness is brand new There was a thread somewhere recently and his issue turned out to be the inner socket disc in his new harness had been installed 180 degrees off.
[Re: Alaskan_TA]
#2765097
04/17/20 03:01 PM
04/17/20 03:01 PM
AndyF
My taillight harness is brand new There was a thread somewhere recently and his issue turned out to be the inner socket disc in his new harness had been installed 180 degrees off. I saw that thread and I checked that. My bulbs are both operating correctly. Each side is on the correct element for run and brake. I also double checked the grounds and they are fine. Adding a second ground doesn't make any difference and the voltage drop to ground is very small. I'm pretty sure it is a problem with the lens.
