ignition coil #276456
04/04/09 07:57 AM
04/04/09 07:57 AM
Northeast
mopar71RR Offline OP
Northeast
Hi,
What coil are you using and would recommend with MP electronic ignition and orange ECU(360)?
Re: ignition coil [Re: mopar71RR] #276457
04/04/09 08:20 AM
04/04/09 08:20 AM
i use an excell 42000v coil on my setup unless you go supercharged or something you dont need anything special. it comes in chrome or yellow and was only 30 bucks.
Re: ignition coil #276458
04/04/09 08:20 AM
04/04/09 08:20 AM
or is it accell? cant remember
Re: ignition coil #276459
04/04/09 08:43 AM
04/04/09 08:43 AM
Valrico FL
1toolguy Offline
1toolguy  Offline
Valrico FL
Just make sure you get the right coil. Accell has two differnt versions the 8140 is the most common one stocked by parts stores and is "universal". UNLESS you have a Mopar electronic ignition that is. It'll cause your ingnition box to over heat and shut down after about 15 minutes of driving, took me months to figure that one out.
You want part #8145, it'll work great.
Re: ignition coil [Re: 1toolguy] #276460
04/04/09 09:38 AM
04/04/09 09:38 AM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
nothing beats a blaster 2 coil. never had a problem with them other then they like to eat cheap wires
Re: ignition coil [Re: n_bogie1984] #276461
04/04/09 03:17 PM
04/04/09 03:17 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree MSD Blaster.Rocky
Chrysler Firepower
Re: ignition coil [Re: n_bogie1984] #276462
04/04/09 03:21 PM
04/04/09 03:21 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
yeper,cant beat em.
Re: ignition coil [Re: bonefish] #276463
04/04/09 03:50 PM
04/04/09 03:50 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
MSD is a very ( if not the most ) reliable coil.
MP coil is the same piece. As far I know MSD manufacturers to MP
Re: ignition coil [Re: NachoRT74] #276464
04/04/09 08:18 PM
04/04/09 08:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the Acell super coil with the MP orange ecu. I have had this setup in a car since 1997 and it still works great. Ron
