Its Time To Build #2764213
04/15/20 12:14 PM
04/15/20 12:14 PM
MR_P_BODY Offline OP
I am so bored I think I will build a break in engine stand.. my last engine is basically done other
than getting PRs.. I have pretty much everything thats needed.. I need to look around to see
if I have a bell housing and a flywheel.. might be one in the pole barn.. any ideas on a trick one..
I use to have one years ago but sold it
wave
Re: Its Time To Build [Re: MR_P_BODY] #2764225
04/15/20 12:46 PM
04/15/20 12:46 PM
Wal Mart sells a kit, I have one in the box still due to a friend having one he loaned me one that he built and then moved to Texas and didn't want it anymore so I bought it cheap enough so I don't want to take the other one out of the box realcrazy
He made his for his BB Mopar only but making other mounts shouldn't be a big deal luck
Re: Its Time To Build [Re: Cab_Burge] #2764233
04/15/20 01:07 PM
04/15/20 01:07 PM
This will be for a SB but I'd like it to be universal to fit anything... I built up about 20 of dyno stands
when I was still at Chrysler.. those would fit anything
wave
Re: Its Time To Build [Re: MR_P_BODY] #2764242
04/15/20 01:17 PM
04/15/20 01:17 PM
moparx Offline
moparx  Offline
please share pics if you do this mr. P. bow
beer
Re: Its Time To Build [Re: moparx] #2764254
04/15/20 01:50 PM
04/15/20 01:50 PM
Will do.. I'm looking for some trick ideas to make this thing nice.. I know on my last stand it had
just the minimum stuff on it to run a engine.. but I have also forgot a lot of stuff since then
so if any one has ideas throw them out there.. I know I will have to find a set of casters so this
will be moveable
wave
Re: Its Time To Build [Re: MR_P_BODY] #2764255
04/15/20 02:01 PM
04/15/20 02:01 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Re: Its Time To Build [Re: OUTLAWSSAA] #2764265
04/15/20 02:35 PM
04/15/20 02:35 PM
Thanks for the pics.. couple of questions.. is that one a store bought one and did you run muffs
wave
Re: Its Time To Build [Re: MR_P_BODY] #2764276
04/15/20 03:00 PM
04/15/20 03:00 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
It belongs to my engine guy, Harry Schillings. He had a bunch of tubing laying around, and welded it all up. As far as mufflers go, he didn't use any. He just opened the door and pointed it outside. Its definitely overkill for a test stand, but that just how he is.
Re: Its Time To Build [Re: OUTLAWSSAA] #2764287
04/15/20 03:27 PM
04/15/20 03:27 PM
It does look nice.. I figured it was from a store and it looks universal.. I wish I would have kept
my drawings from the ones I made at work.. I remember some of the details.. I think I will make
this new one like those.. I'll have to check what I have for tubing.. the other ones used 2X3 tubing
wave
Re: Its Time To Build [Re: MR_P_BODY] #2764317
04/15/20 04:31 PM
04/15/20 04:31 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
MIKE, Just to let you know if you want I have a a run stand you can borrow any time you want. It gets used maybe 3 times year. Your more than welcome to use it.
JAKES AUTOMOTIVE
Re: Its Time To Build [Re: JAKE68] #2764322
04/15/20 04:38 PM
04/15/20 04:38 PM
Thanks much.. I may take you up on that.. would save me time.. I will still have to see if I have a bell
housing and a fly wheel to get it hooked up.. THANKS up
wave
Re: Its Time To Build [Re: MR_P_BODY] #2764362
04/15/20 06:11 PM
04/15/20 06:11 PM
I wish I had a old stock conv that I could cut so I have a flex plate.. I have a trans case that I will
cut up.. trying to get this whole thing small enough and light.. all I have are 8" converters
wave
Re: Its Time To Build [Re: MR_P_BODY] #2764369
04/15/20 06:30 PM
04/15/20 06:30 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Mike see if you can find an outdated Chevy type flywheels used on a powerglide to Mopar change over. I have one with elongated holes that I was going to use on my 80% finished engine stand. I’m going to sell mine but I’m to far away from you.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Its Time To Build [Re: pittsburghracer] #2764376
04/15/20 06:50 PM
04/15/20 06:50 PM
If you get out to your shop see if you can measure the OD on your plate.. I might be able to make one
wave
Re: Its Time To Build [Re: MR_P_BODY] #2764445
04/15/20 10:31 PM
04/15/20 10:31 PM
PA.
"Little"John
"Little"John
PA.
wave
Mike I ran downstairs and took a couple pictures. My tape measure is out in the shop but it looks like using a 12 inch ruler to be 13 inches. It would be the same as a ring gear on a Mopar convertor. I posted a picture of some of the adapters for my different set ups.
137A80B8-DD6A-4A10-B4AD-792C9A51BF7E.jpeg4113F796-34A0-48BD-830C-57682D524C96.jpeg15F64A5C-7F38-4D8B-B8CC-43CDC6377E7A.jpeg
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Its Time To Build [Re: pittsburghracer] #2764449
04/15/20 10:51 PM
04/15/20 10:51 PM
How much are you looking for to sell it.. where did you get it at
wave
Re: Its Time To Build [Re: MR_P_BODY] #2764452
04/15/20 11:15 PM
04/15/20 11:15 PM
PA.
"Little"John
"Little"John
PA.
wave
Mike if I sell it I gotta get 250.00 out of it but I won't ship it. It comes with a flywheel that has egged holes on it but would work great for a stand, An adapter I bought from a moparts member to mount a starter on a big block mopar, and a set of small gauges I bought new for this stand. Wheels are already welded on and as you can see from the pictures the legs extend out for stability. I bought the plans from a guy on Ebay.
[Linked Image]New engine breakin bench 003 by John Cadamore, on Flickr
[Linked Image]engine stand 002 by John Cadamore, on Flickr
[Linked Image]engine stand 001 by John Cadamore, on Flickr
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Its Time To Build [Re: MR_P_BODY] #2764539
04/16/20 10:27 AM
04/16/20 10:27 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
you can buy a new flywheel at jegs $96, add some $3 trinket for free shipping.
https://www.jegs.com/i/JEGS/555/601400/10002/-1
Joe
Without Data, you’re just another guy with an opinion.
Re: Its Time To Build [Re: sr4440] #2764558
04/16/20 10:56 AM
04/16/20 10:56 AM
Really thats all I need to attach the engine to a trans set up.. I think I will look into that.. thanks
wave
Re: Its Time To Build [Re: MR_P_BODY] #2765273
04/17/20 10:03 PM
04/17/20 10:03 PM
Alberta
440_Offroader Offline
Alberta
I thought I read somewhere that you needed to use a 130 tooth flywheel in an auto trans housing... Maybe someone can confirm?
