oxy/acetylene heating Q #2763779
04/14/20 10:58 AM
04/14/20 10:58 AM
RapidRobert Offline OP
I have some rear shackles that I need to remove from the leafs & the nuts are solid tight & I dont want to break em off & ruin it. My nut cracker is broken so can I heat the nut with the hot wrench cherry red then remove it or will that weaken the bolt? thank you for your time
Re: oxy/acetylene heating Q [Re: RapidRobert] #2763787
04/14/20 11:09 AM
04/14/20 11:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The shackle is just cold roll material
wave
Re: oxy/acetylene heating Q [Re: MR_P_BODY] #2763789
04/14/20 11:11 AM
04/14/20 11:11 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It'll be fine. If in doubt, replace the nut.
Doug
Re: oxy/acetylene heating Q [Re: MR_P_BODY] #2763792
04/14/20 11:12 AM
04/14/20 11:12 AM
I worried that if I heat the nut cherry red that it will weaken the bolt that it is on. Am I worried over nothing?
Re: oxy/acetylene heating Q [Re: RapidRobert] #2763795
04/14/20 11:19 AM
04/14/20 11:19 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I use strong heat when nothing else works. Since you are going to heat them, try this first. Heat them enough so that they start to smoke, something other than burning off road debris. When hot enough, melt wax from the top down, crayon works. The wax runs down the threads and allows for the break. Works 90% of the time. If not, you are close to half way there with the heating.
Re: oxy/acetylene heating Q [Re: RapidRobert] #2763796
04/14/20 11:19 AM
04/14/20 11:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your over thinking it.. heat it up
wave
Re: oxy/acetylene heating Q [Re: RapidRobert] #2763801
04/14/20 11:30 AM
04/14/20 11:30 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Rubber/urethane bushing? I wonder if it's true. I was told if you breathe burning urethane it will kill you.
2011 Drag Pak Challenger
Re: oxy/acetylene heating Q [Re: rickseeman] #2763811
04/14/20 11:45 AM
04/14/20 11:45 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Fuel tank is right there Robert, so be careful.
Just heat the nut, not the bolt.
Mo' Farts
Moderated by "tbagger".
Re: oxy/acetylene heating Q [Re: rickseeman] #2763812
04/14/20 11:45 AM
04/14/20 11:45 AM
the nut is on the other side of the shackle flat piece so I think I'm good on the fumes (if I work fast). I dont have a crayon handy so I will go ahead & heat it up. Thanks guys up
Re: oxy/acetylene heating Q [Re: rickseeman] #2763817
04/14/20 11:51 AM
04/14/20 11:51 AM
moparx Offline
moparx  Offline
either one inhaled ain't good for you !
i use the heat/wax, birthday candle, crayon trick all the time. that works GREAT ! i removed all the tiny slot screws from the cowl vent screen from my 1933 dodge "humpback" panel delivery project using this method, and half of them had the screwdriver slot in the screw head almost rusted away.
beer
Re: oxy/acetylene heating Q [Re: moparx] #2763821
04/14/20 12:06 PM
04/14/20 12:06 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
beer
Put the fire to the flat side of the nut until it shows some color and spin the nut off. Don't use your fingers... lol.
If it doesn't go well, new shackles aren't that expensive.
Kevin
Re: oxy/acetylene heating Q [Re: Twostick] #2763860
04/14/20 01:38 PM
04/14/20 01:38 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
X2 on using wax. I use gulf wax, never had rusted nut or bolt not come apart. Just heat & apply nurmerous times.
Re: oxy/acetylene heating Q [Re: rickraw] #2763875
04/14/20 02:43 PM
04/14/20 02:43 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Maybe you should consider getting a new nut splitter?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: oxy/acetylene heating Q [Re: Hemi_Joel] #2763887
04/14/20 03:19 PM
04/14/20 03:19 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Never really needed one for 45yrs.
Re: oxy/acetylene heating Q [Re: rickraw] #2763908
04/14/20 03:58 PM
04/14/20 03:58 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
PB Blaster is a good product to help get stuff apart...if it's salvageable. Sometimes new parts are the correct answer.
Re: oxy/acetylene heating Q [Re: CMcAllister] #2763913
04/14/20 04:01 PM
04/14/20 04:01 PM
I'll get on it, I appreciate the advice/help. Thank you!
Re: oxy/acetylene heating Q [Re: RapidRobert] #2764192
04/15/20 11:37 AM
04/15/20 11:37 AM
Missouri
randavis Offline
randavis  Offline
Missouri
Sometimes, two heat cycles will work. I used to work at and asphalt plant and most of it was bolted together. Everything rusted. We would heat the nut to the point that some color appeared and then let it air cool. Then we would heat it up again and put a wrench on it. I don't know why it worked, it just did.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: oxy/acetylene heating Q [Re: randavis] #2764196
04/15/20 11:45 AM
04/15/20 11:45 AM
I couldn't find a nut splitter on hand locally so I will try that
Re: oxy/acetylene heating Q [Re: RapidRobert] #2764203
04/15/20 11:59 AM
04/15/20 11:59 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
That candle trick is pretty slick. Or give it a good soaking in Aero-Kroil..... work
Re: oxy/acetylene heating Q [Re: bobby66] #2764216
04/15/20 12:20 PM
04/15/20 12:20 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I had a stuck nut on a shackle and it was rounded over. I took my MIG and welded two wings on the nut so a ViceGrip had some thing to grab on to. This got the nut real hot. While still very warm I sprayed PB Buster on the threads, let cool and it spun off real quick. Then just replaced the nut with a stainless steel one.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
