oxy/acetylene heating Q
#2763779
04/14/20 10:58 AM
04/14/20 10:58 AM
RapidRobert
I have some rear shackles that I need to remove from the leafs & the nuts are solid tight & I dont want to break em off & ruin it. My nut cracker is broken so can I heat the nut with the hot wrench cherry red then remove it or will that weaken the bolt? thank you for your time
Re: oxy/acetylene heating Q
[Re: MR_P_BODY]
#2763792
04/14/20 11:12 AM
04/14/20 11:12 AM
RapidRobert
I worried that if I heat the nut cherry red that it will weaken the bolt that it is on. Am I worried over nothing?
[Re: rickseeman]
#2763811
04/14/20 11:45 AM
04/14/20 11:45 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Fuel tank is right there Robert, so be careful.
Just heat the nut, not the bolt.
Mo' Farts
Moderated by "tbagger".
[Re: moparx]
#2763821
04/14/20 12:06 PM
04/14/20 12:06 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
either one inhaled ain't good for you ! i use the heat/wax, birthday candle, crayon trick all the time. that works GREAT ! i removed all the tiny slot screws from the cowl vent screen from my 1933 dodge "humpback" panel delivery project using this method, and half of them had the screwdriver slot in the screw head almost rusted away. Put the fire to the flat side of the nut until it shows some color and spin the nut off. Don't use your fingers... lol. If it doesn't go well, new shackles aren't that expensive. Kevin
[Re: rickraw]
#2763875
04/14/20 02:43 PM
04/14/20 02:43 PM
Posts: 7,493 Minnesota
Hemi_Joel
Minnesota
Maybe you should consider getting a new nut splitter?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: rickraw]
#2763908
04/14/20 03:58 PM
04/14/20 03:58 PM
Posts: 11,606 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
PB Blaster is a good product to help get stuff apart...if it's salvageable. Sometimes new parts are the correct answer.
[Re: CMcAllister]
#2763913
04/14/20 04:01 PM
04/14/20 04:01 PM
RapidRobert
I'll get on it, I appreciate the advice/help. Thank you!
[Re: RapidRobert]
#2764192
04/15/20 11:37 AM
04/15/20 11:37 AM
Posts: 144 Missouri
randavis
Missouri
Sometimes, two heat cycles will work. I used to work at and asphalt plant and most of it was bolted together. Everything rusted. We would heat the nut to the point that some color appeared and then let it air cool. Then we would heat it up again and put a wrench on it. I don't know why it worked, it just did.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: randavis]
#2764196
04/15/20 11:45 AM
04/15/20 11:45 AM
RapidRobert
I couldn't find a nut splitter on hand locally so I will try that
[Re: bobby66]
#2764216
04/15/20 12:20 PM
04/15/20 12:20 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I had a stuck nut on a shackle and it was rounded over. I took my MIG and welded two wings on the nut so a ViceGrip had some thing to grab on to. This got the nut real hot. While still very warm I sprayed PB Buster on the threads, let cool and it spun off real quick. Then just replaced the nut with a stainless steel one.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
