383 speed pro 2315 pistons assembly
#2763415
04/13/20 12:41 PM
04/13/20 12:41 PM
Posts: 106 Poland
willard
Poland
Hi I ordered a set of flat top 383 pistons - speed pro 2315s - I got 8 ea having arrow in the same direction. Shouldnt there be 4 left and 4 right for each bank? Or they are interchangeable right/left ? The supplier doesnt state there are left/right versions while ordering separate pistons... thanks
Re: 383 speed pro 2315 pistons assembly
[Re: lewtot184]
#2763469
04/13/20 01:45 PM
04/13/20 01:45 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
And...... 2315’s have offset pins. The arrow points towards the front so the offset is oriented correctly.
Pistons with no pin offset and either no valve pockets or symmetrical pockets can go in any hole.
[Re: fast68plymouth]
#2763497
04/13/20 03:19 PM
04/13/20 03:19 PM
Posts: 106 Poland
willard
Poland
Ok, the pin is offset but top is flat so one side can have arrow to the front and the other to the back? Definaty the set I got has 8 pistons of the same constructon and markings.
[Re: willard]
#2763763
04/14/20 10:15 AM
04/14/20 10:15 AM
fast68plymouth
So. Burlington, Vt.
It really couldn’t be any simpler. L2315’s are a forged stock replacement piston. Just like the OE pistons they replace, there is no left or right.
Just install on the rods correctly so that when installed in the motor, the arrows point towards the front.
[Re: willard]
#2763823
04/14/20 12:07 PM
04/14/20 12:07 PM
Posts: 10,743 North Dakota
6PakBee
North Dakota
Hi I ordered a set of flat top 383 pistons - speed pro 2315s - I got 8 ea having arrow in the same direction. Shouldnt there be 4 left and 4 right for each bank? Or they are interchangeable right/left ? The supplier doesnt state there are left/right versions while ordering separate pistons... thanks I'm curious, what heads are you using and what compression ratio are you going to end up with? Thanks.
#2763843
04/14/20 12:46 PM
04/14/20 12:46 PM
Posts: 3,916 usa
lewtot184
usa
Just install on the rods correctly so that when installed in the motor, the arrows point towards the front. this! "couldn't be simpler".
