383 speed pro 2315 pistons assembly #2763415
04/13/20 12:41 PM
04/13/20 12:41 PM
Poland
W
willard Offline OP
willard  Offline OP
W
Poland
Hi I ordered a set of flat top 383 pistons - speed pro 2315s - I got 8 ea having arrow in the same direction. Shouldnt there be 4 left and 4 right for each bank? Or they are interchangeable right/left ? The supplier doesnt state there are left/right versions while ordering separate pistons...
thanks
Re: 383 speed pro 2315 pistons assembly [Re: willard] #2763455
04/13/20 01:33 PM
04/13/20 01:33 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
rights and lefts are more specific for pistons with asymmetrical valve reliefs; which the 2315's don't have. .
Re: 383 speed pro 2315 pistons assembly [Re: lewtot184] #2763469
04/13/20 01:45 PM
04/13/20 01:45 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
And...... 2315’s have offset pins.
The arrow points towards the front so the offset is oriented correctly.
Pistons with no pin offset and either no valve pockets or symmetrical pockets can go in any hole.
Re: 383 speed pro 2315 pistons assembly [Re: fast68plymouth] #2763497
04/13/20 03:19 PM
04/13/20 03:19 PM
Poland
W
willard Offline OP
willard  Offline OP
W
Poland
Ok, the pin is offset but top is flat so one side can have arrow to the front and the other to the back? Definaty the set I got has 8 pistons of the same constructon and markings.
Re: 383 speed pro 2315 pistons assembly [Re: willard] #2763531
04/13/20 04:39 PM
04/13/20 04:39 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I believe the arrow should point to the front on both sides.
Re: 383 speed pro 2315 pistons assembly [Re: stumpy] #2763532
04/13/20 04:42 PM
04/13/20 04:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the arrows should point to the front on both sides. IIRC the font will be right side up on one side and upside down on the other. of course you could do the old time speed secret and put them in backwards (arrows on both sides facing to the rear).
Re: 383 speed pro 2315 pistons assembly [Re: lewtot184] #2763708
04/14/20 04:23 AM
04/14/20 04:23 AM
Poland
W
willard Offline OP
willard  Offline OP
W
Poland
to make it clear - are there speed pro 2315 pistons in LEFT and RIGHT option
or
there is only ONE shape/dimension/construction and I just follow the arrows?
Re: 383 speed pro 2315 pistons assembly [Re: willard] #2763740
04/14/20 08:59 AM
04/14/20 08:59 AM
A727Tflite Offline
A727Tflite  Offline
Lay the pistons on your bench with arrows facing you.
The pins will be offset to the left.
If so - you have the correct pistons.
Re: 383 speed pro 2315 pistons assembly [Re: A727Tflite] #2763756
04/14/20 09:55 AM
04/14/20 09:55 AM
Poland
W
willard Offline OP
willard  Offline OP
W
Poland
thanks!
Re: 383 speed pro 2315 pistons assembly [Re: willard] #2763763
04/14/20 10:15 AM
04/14/20 10:15 AM
So. Burlington, Vt.
So. Burlington, Vt.
It really couldn’t be any simpler.
L2315’s are a forged stock replacement piston.
Just like the OE pistons they replace, there is no left or right.
Just install on the rods correctly so that when installed in the motor, the arrows point towards the front.
Re: 383 speed pro 2315 pistons assembly [Re: fast68plymouth] #2763772
04/14/20 10:39 AM
04/14/20 10:39 AM
A727Tflite Offline
A727Tflite  Offline
Williard - the arrows mean nothing to performance or NVH. They are simply installation aids.
I have seen many parts mistamped in 50 years. I’m not saying your pistons are mistamped.
If you want to make sure you install the pistons correctly check the pin offset.
Paying attention to detail usually pays off in the end.
Re: 383 speed pro 2315 pistons assembly [Re: willard] #2763823
04/14/20 12:07 PM
04/14/20 12:07 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
thanks
I'm curious, what heads are you using and what compression ratio are you going to end up with? Thanks.
Re: 383 speed pro 2315 pistons assembly [Re: fast68plymouth] #2763843
04/14/20 12:46 PM
04/14/20 12:46 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
this! "couldn't be simpler".
