DEAD CYLINDER #2763521
04/13/20 04:26 PM
04/13/20 04:26 PM
Georgia
K
kimber Offline OP
kimber  Offline OP
K
Georgia
I HAVE A 318 IN MY 65 PLYMOUTH SATELLITE. LATELY IT STARTED POPPING WHILE IDLING. I CHECKED TO SEE WHICH CYLINDER WASN'T FIRING AND FOUND OUT THAT #8 IS NOT. I PUT A NEW PLUG AND IT IS STILL NOT FIRING ON THAT CYLINDER. ANYBODY HAS AN IDEA WHY IT IS NOT FIRING? IT JUST STARTED DOPING IT YESTERDAY. THANKS FOR ANY HELP.
Re: DEAD CYLINDER [Re: kimber] #2763524
04/13/20 04:30 PM
04/13/20 04:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Start with a compression check.
Re: DEAD CYLINDER [Re: kimber] #2763553
04/13/20 05:27 PM
04/13/20 05:27 PM
Keizer, Oregon U.S.A.
E
elmor353 Online content
elmor353  Online Content
E
When you say "popping", is it popping through the carb or through the exhaust? Either way, a compression test will tell you more. Could be a blown head gasket allowing the adjacent cylinder to fire into that cylinder, or you have a burnt or bent valve.
Re: DEAD CYLINDER [Re: kimber] #2763565
04/13/20 05:57 PM
04/13/20 05:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Bent push rods and push rods punched through rocker arms or lifters are fairly common on small blocks.
Removing a valve cover is a quick way to take a look inside.
Re: DEAD CYLINDER [Re: Alaskan_TA] #2763601
04/13/20 07:11 PM
04/13/20 07:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Is it an LA or Poly version ?
Re: DEAD CYLINDER [Re: TJP] #2765633
04/18/20 07:51 PM
04/18/20 07:51 PM
Oly Wash
racerlall Offline
racerlall  Offline
Oly Wash
If it a poly adjust the valves
Re: DEAD CYLINDER [Re: racerlall] #2765646
04/18/20 08:14 PM
04/18/20 08:14 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Before we jump on anything, did you check to see if you even had spark on number 8? Might just be a bad plug wire or even the cap.
Re: DEAD CYLINDER [Re: Sniper] #2765726
04/19/20 12:01 AM
04/19/20 12:01 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
...or possible small vacuum leak could have dropping of that cyl at idle, but small brake torque should bring it back for diagnosis sake.
