Anyone doing CNP read this. #2763337
04/13/20 10:00 AM
04/13/20 10:00 AM
Midwest
fuseable Online rolleyes OP
fuseable  Online Rolleyes OP
Midwest
Just a FYI for anyone doing a big block or gen 2 Hemi CNP EFI setup.
Had my cam position sensor shoot craps after 5 years, magnet must have come loose inside sensor. No damage to anything but sensor. Cost me a 100 for a tow. Will carry a spare sensor from now on, 30 dollar part.
Re: Anyone doing CNP read this. [Re: fuseable] #2763347
04/13/20 10:17 AM
04/13/20 10:17 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Interesting, did you get a tow because of the part failure or would it not run without the cam signal? Mine will just go to batch fire from sequential if it loses the cam signal. I run that same sensor and it so far has been trouble free, I ran one from a 200,000 mile jeep engine until it started leaking oil out of the top, then I moved to a reman parts house one.
68 Barracuda Formula S 340
Re: Anyone doing CNP read this. [Re: Bad340fish] #2763350
04/13/20 10:32 AM
04/13/20 10:32 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Looks like one of mine. I'll send you a backup for free if it was.
Re: Anyone doing CNP read this. [Re: fuseable] #2763352
04/13/20 10:44 AM
04/13/20 10:44 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
I have that Jeep cam sensor plus adapter from Jerry. But then I found this: https://www.aemelectronics.com/products/ignition-components/engine-position-module-epm and AR Engineering made a slick adapter to drop the AEM "puck" into a Hemi or RB, AR also threw in another timing signal generation wheel so you can get two different signals and chose whichever one works best with your ECU. The AEM puck gives you crank signal plus cam signal so it's a one stop solution. Very slick stuff. I'm still working on my high-pressure fuel system. More parts give you more options so you can never have too many parts wink
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Anyone doing CNP read this. [Re: rumblefish72] #2763365
04/13/20 11:25 AM
04/13/20 11:25 AM
Midwest
Midwest
Rich it is not one of yours, thanks for the offer though. It is the same sensor (I believe) but it is the jeep 4.0 cam sync with a aluminum adaptor.
Re: Anyone doing CNP read this. [Re: fuseable] #2763377
04/13/20 11:48 AM
04/13/20 11:48 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
We are going to need another shot of that engine, looks awesome just from that one shot!
Re: Anyone doing CNP read this. [Re: Bad340fish] #2763384
04/13/20 11:56 AM
04/13/20 11:56 AM
Midwest
Midwest
Everyone stay safe.
Re: Anyone doing CNP read this. [Re: fuseable] #2763390
04/13/20 12:00 PM
04/13/20 12:00 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That looks great, the hard lines are a nice touch!
Re: Anyone doing CNP read this. [Re: fuseable] #2763407
04/13/20 12:36 PM
04/13/20 12:36 PM
AndyF Offline
AndyF  Offline
That seems like really bad luck or else it was a cheap Chinese knock off part. The OEM grade sensors should last at least 100K if not more.
Re: Anyone doing CNP read this. [Re: AndyF] #2763414
04/13/20 12:40 PM
04/13/20 12:40 PM
Midwest
Midwest
It was a Standard Motor Products sensor.
No big deal, but I will always carry a spare and a spare crank sensor from now on, both a lot cheaper than a tow. Luckily I was 5 miles from the house.
Re: Anyone doing CNP read this. [Re: fuseable] #2763534
04/13/20 04:47 PM
04/13/20 04:47 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
This is ours
Re: Anyone doing CNP read this. [Re: Mopar_Rich] #2763542
04/13/20 05:01 PM
04/13/20 05:01 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
OOOH that's nice! Where do ya find these?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Anyone doing CNP read this. [Re: Mopar_Rich] #2763575
04/13/20 06:36 PM
04/13/20 06:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted by Mopar_Rich
This is ours
Thats what I have.. nice piece
wave
Re: Anyone doing CNP read this. [Re: HOTMOPR] #2763592
04/13/20 07:04 PM
04/13/20 07:04 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Andy at AR makes them and I sell and support them. Go to my website and look under Products - CNP for Mopars.
