Re: Anyone doing CNP read this.
[Re: fuseable]
#2763347
04/13/20 10:17 AM
04/13/20 10:17 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Interesting, did you get a tow because of the part failure or would it not run without the cam signal? Mine will just go to batch fire from sequential if it loses the cam signal. I run that same sensor and it so far has been trouble free, I ran one from a 200,000 mile jeep engine until it started leaking oil out of the top, then I moved to a reman parts house one.
68 Barracuda Formula S 340
[Re: fuseable]
#2763352
04/13/20 10:44 AM
04/13/20 10:44 AM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
I have that Jeep cam sensor plus adapter from Jerry. But then I found this: https://www.aemelectronics.com/products/ignition-components/engine-position-module-epm and AR Engineering made a slick adapter to drop the AEM "puck" into a Hemi or RB, AR also threw in another timing signal generation wheel so you can get two different signals and chose whichever one works best with your ECU. The AEM puck gives you crank signal plus cam signal so it's a one stop solution. Very slick stuff. I'm still working on my high-pressure fuel system. More parts give you more options so you can never have too many parts
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: fuseable]
#2763377
04/13/20 11:48 AM
04/13/20 11:48 AM
Bad340fish
Tulsa OK
We are going to need another shot of that engine, looks awesome just from that one shot!
[Re: fuseable]
#2763390
04/13/20 12:00 PM
04/13/20 12:00 PM
Bad340fish
Tulsa OK
That looks great, the hard lines are a nice touch!
[Re: Mopar_Rich]
#2763542
04/13/20 05:01 PM
04/13/20 05:01 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
OOOH that's nice! Where do ya find these?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
