Re: could this nos ignition switch cause a voltage drop?
[Re: nates69b]
#2762802
04/11/20 06:23 PM
04/11/20 06:23 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Check the voltage at the ignition terminal of the voltage regulator. Compare it to the battery voltage. They should be close - if not then the ignition switch could have a high resistance in the contacts.
[Re: Cab_Burge]
#2762844
04/11/20 08:26 PM
04/11/20 08:26 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Does your car still have the original mechanical voltage regulator? Will the voltage increase if you speed the RPM up? Me thinks you may have continuity issues now on the firewall gang connector after moving the main under dash wiring harness around ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) There is no magic in wiring with electricity , it is either connected good, not so good or bad ![work work](/ubbthreads/images/graemlins/custom/work.gif) BTW, it took me quite a while to figure that out working for the telephone company 33 yrs, I retired long time ago in 1996 Yes a part open will cause a voltage drop and spikes. Cab, here ya go. Bet you know how to 'KICK' a wire pair. ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2765577
04/18/20 05:27 PM
04/18/20 05:27 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I don't recognize that meter, what is it? I started off as a apprentice lineman and worked in pole line construction and got bore after 15 months so I transferred into customer services I&M,(installation and maintenance) for the next 13 yrs, we had little Triplet VOM to use for trouble shooting ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) I have two of them in my shop still ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Along with a Fluke 87 digital VOM hat was provided to me to evaluate for field use, it works good also ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif) Direct current is very basic, no magic as long as you under stand the theory on current flow. All the phone companies I know of used A.C. for ring current and D.C. for talking on. That was over 24 yrs ago when I was RIF so I have no clue what technology is being used now, especially on wireless and Smart phones ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: Cab_Burge]
#2765602
04/18/20 06:36 PM
04/18/20 06:36 PM
Dave_J
Auburn WA
Cab, Its a 3 wire (Ground lead) for testing cable pairs. It can be used to test Tip/Ring grounds and to 'Kick" the cable for distance. Very basic compared to what the tech's use today. 43 years in I&M but mostly Key telephone and Switching systems in US ARMY.
One wire DC circuits are kind of simple if you 'Divide and Conquer'. Split it down to sections and go 1 step at a time. Any connector is subject to failure, any ground can go open and any relay or switch can fail.
