Fuel distribution issues #2762568
04/11/20 06:48 AM
04/11/20 06:48 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
After a spirited first test ride of this year I had some oil leaks in the valley tray, so I remove the intake to fix and notice I have 2 intake ports in the heads soaking wet with fuel. The wet ports have no staining from the red fuel I used, but all the others are dry and stained. I use the Indy 400-3 intake and can only figure I have a distribution issue here. Cylinder intake ports #6 and #7. How to fix?
Re: Fuel distribution issues [Re: mopar dave] #2762569
04/11/20 06:59 AM
04/11/20 06:59 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
What do the plugs look like?
Re: Fuel distribution issues [Re: Wirenut] #2762574
04/11/20 07:24 AM
04/11/20 07:24 AM
Mt Morris Michigan
Mt Morris Michigan
They burn darker than the others. #7 has always been a problem.
Re: Fuel distribution issues [Re: mopar dave] #2762608
04/11/20 09:31 AM
04/11/20 09:31 AM
Mt Morris Michigan
Mt Morris Michigan
Anyone every see anything like this before?
Re: Fuel distribution issues [Re: mopar dave] #2762614
04/11/20 09:51 AM
04/11/20 09:51 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I can tell you from running 10 o2 sensors, fuel distribution moves around alot, based on RPM and load. I would look at the plugs and see if they are the same, if they are i wouldn't worry about it.
Joe
Without Data, you’re just another guy with an opinion.
Re: Fuel distribution issues [Re: mopar dave] #2762626
04/11/20 10:20 AM
04/11/20 10:20 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
If its a carb and the plugs are not real dark like black , and if the oil dosnt smell badly of gas I wouldn't be too concerned. Judging by the heads you are using this is a hot rod , not a mild build. If its a carb its just not a perfect system . If you smell the gas in the oil quickly after an oil change you should be concerned about cylinder wash down .
Just my experience and observation.
Re: Fuel distribution issues [Re: Wirenut] #2762631
04/11/20 10:32 AM
04/11/20 10:32 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I have dealt with this on 6bbl intakes.
Not going to be WOT fuel issue.
Idle/ part throttle and coasting.
Fuel puddling on floor and running in wet.
Small dam on runner floor fixed it for me.
Didn't effect WOT in my experience.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Fuel distribution issues [Re: mopar dave] #2762635
04/11/20 11:02 AM
04/11/20 11:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You need to run 1 or 2 heat ranges hotter in the 2 cyls that are running fat.. just the
cyls that are fat
wave
Re: Fuel distribution issues [Re: MR_P_BODY] #2762655
04/11/20 11:45 AM
04/11/20 11:45 AM
Mt Morris Michigan
Mt Morris Michigan
ok, I can run a different plug I the rich cylinders. Dom suggested same thing. I could mount a turtle in the bottom of the intake as well I guess. It may be just an issue at idle, but if it was seems like all the ports would be stained red.
Re: Fuel distribution issues [Re: mopar dave] #2762660
04/11/20 11:48 AM
04/11/20 11:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont start adding things.. one step at a time
wave
Re: Fuel distribution issues [Re: mopar dave] #2762674
04/11/20 12:24 PM
04/11/20 12:24 PM
Which version is your intake, early 440-3 (round individual injector bungs,, late 440-3 or 440-3X?
They are all different under the carbs. scope
Re: Fuel distribution issues [Re: Cab_Burge] #2762783
04/11/20 05:47 PM
04/11/20 05:47 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
fuel pressure above 5psi floates set too high
Re: Fuel distribution issues [Re: Cab_Burge] #2762826
04/11/20 07:35 PM
04/11/20 07:35 PM
Mt Morris Michigan
Mt Morris Michigan
I believe its a later version cab because I bought it new 4 years ago. Looks a little different now that I removed the clover leaf.
Re: Fuel distribution issues [Re: 540DUSTER] #2762827
04/11/20 07:36 PM
04/11/20 07:36 PM
Mt Morris Michigan
Mt Morris Michigan
I run my pressure at 5.5psi and floats just below middle of site glass.
Re: Fuel distribution issues [Re: mopar dave] #2762858
04/11/20 08:56 PM
04/11/20 08:56 PM
Mt Morris Michigan
Mt Morris Michigan
This video might make things a little more helpful. https://youtu.be/CBqd4WO9BzQ
Re: Fuel distribution issues [Re: mopar dave] #2762889
04/11/20 10:43 PM
04/11/20 10:43 PM
That is the later 440-3, not the early one with the cast in round bungs for tapping for EFI injectors. I'm sure it is not the taller bigger plenum 440-3X either.
Re: Fuel distribution issues [Re: Cab_Burge] #2762945
04/12/20 08:57 AM
04/12/20 08:57 AM
Mt Morris Michigan
Mt Morris Michigan
No, it’s not the 3x. It is a 400-3. For now I just removed the 1” 4 hole tapered and used a 1/2” wood straight 4 hole. I keep an eye on it. Never used red fuel before, so it’s working for my like a figure print.
Re: Fuel distribution issues [Re: mopar dave] #2762948
04/12/20 09:19 AM
04/12/20 09:19 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Do you run a spacer that is modified to match the top of the manifold? Or are you putting the carb directly on whats in that picture?
Re: Fuel distribution issues [Re: B1MAXX] #2762949
04/12/20 09:28 AM
04/12/20 09:28 AM
Mt Morris Michigan
Mt Morris Michigan
The wilsons tapered 4 hole matched fairly well to the carb pad opening and I was following their direction with the removal of the clover leaf and putting their spacer on top. The straight 4 hole obviously covers more of the carb pad, so will see how this works out. May just be a common issue with this intake and I found it with the red dye in the fuel. Gonna call Brodix Monday and see what they say about a turtle in this intake just for curiosity.
Re: Fuel distribution issues [Re: mopar dave] #2762958
04/12/20 10:09 AM
04/12/20 10:09 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I don't like the idea of a 4 hole on that just my gut reaction, that there would be reversion with 4 holes dumping into a plenum that wide open. I would run an open spacer (a cheapie) of 1"-2" inches.
