Re: Fuel distribution issues
[Re: mopar dave]
#2762614
04/11/20 09:51 AM
04/11/20 09:51 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I can tell you from running 10 o2 sensors, fuel distribution moves around alot, based on RPM and load. I would look at the plugs and see if they are the same, if they are i wouldn't worry about it.
Joe
Without Data, you’re just another guy with an opinion.
[Re: mopar dave]
#2762626
04/11/20 10:20 AM
04/11/20 10:20 AM
Posts: 630 Ct
Wirenut
Ct
They burn darker than the others. #7 has always been a problem. If its a carb and the plugs are not real dark like black , and if the oil dosnt smell badly of gas I wouldn't be too concerned. Judging by the heads you are using this is a hot rod , not a mild build. If its a carb its just not a perfect system . If you smell the gas in the oil quickly after an oil change you should be concerned about cylinder wash down . Just my experience and observation.
[Re: Wirenut]
#2762631
04/11/20 10:32 AM
04/11/20 10:32 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
I have dealt with this on 6bbl intakes. Not going to be WOT fuel issue. Idle/ part throttle and coasting. Fuel puddling on floor and running in wet. Small dam on runner floor fixed it for me. Didn't effect WOT in my experience.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: mopar dave]
#2762635
04/11/20 11:02 AM
04/11/20 11:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
They burn darker than the others. #7 has always been a problem. You need to run 1 or 2 heat ranges hotter in the 2 cyls that are running fat.. just the cyls that are fat
[Re: mopar dave]
#2762674
04/11/20 12:24 PM
04/11/20 12:24 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
Which version is your intake, early 440-3 (round individual injector bungs,, late 440-3 or 440-3X? They are all different under the carbs.
[Re: mopar dave]
#2762889
04/11/20 10:43 PM
04/11/20 10:43 PM
Cab_Burge
That is the later 440-3, not the early one with the cast in round bungs for tapping for EFI injectors. I'm sure it is not the taller bigger plenum 440-3X either.
[Re: B1MAXX]
#2762949
04/12/20 09:28 AM
04/12/20 09:28 AM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
The wilsons tapered 4 hole matched fairly well to the carb pad opening and I was following their direction with the removal of the clover leaf and putting their spacer on top. The straight 4 hole obviously covers more of the carb pad, so will see how this works out. May just be a common issue with this intake and I found it with the red dye in the fuel. Gonna call Brodix Monday and see what they say about a turtle in this intake just for curiosity.
