Magnum threaded fan mount extension?? #2762318
04/10/20 01:44 PM
04/10/20 01:44 PM
West Coast, USA
jbc426 Offline OP
jbc426  Offline OP
West Coast, USA
Has anyone ever seen an extension to extend the fan forward on a 5.9 or 5.2 Magnum serpentine belt set-up? I need one to make room for the belt on a belt driven supercharger set-up.
Re: Magnum threaded fan mount extension?? [Re: jbc426] #2762380
04/10/20 03:41 PM
04/10/20 03:41 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Maybe just me but I'd ditch the propeller and run a good dual electric and controllers. Less rotational mass too.
But to anwser, NO, I have not.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Magnum threaded fan mount extension?? [Re: Dave_J] #2762386
04/10/20 03:56 PM
04/10/20 03:56 PM
okla.
sam64 Offline
sam64  Offline
okla.
If you know a good parts person they can help by looking at the dimension section for fan clutches. I had to do this for the one in my 65 Coronet with a 5.7 hemi. I had to have a shorter shaft.
Re: Magnum threaded fan mount extension?? [Re: jbc426] #2762418
04/10/20 04:57 PM
04/10/20 04:57 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Factory had different length fan clutchs. For example, a v6 fan had a very long threaded portion. The 92-93 magnums had a mid sized one. The 94-03s varied a little based on HD cooling or not, or at least thats been my obervation with my junkyard engines. My 92 w250 had a spacer washer behind the fan clutch as well to get an extra 3/16 inch forward. Only seen them on 92-93s though, and not all of them. Very thick metal washer - not a hardware store piece without alot of milling.
Re: Magnum threaded fan mount extension?? [Re: jerseybud] #2763168
04/12/20 07:26 PM
04/12/20 07:26 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Another vote for electric fan time.
Eliminate dead weight, pick up horsepower, less noise, and more room. up
Otherwise, you could add a short threaded section and then thread another nut on there and put it on?
Mo' Farts
Moderated by "tbagger".
Re: Magnum threaded fan mount extension?? [Re: Grizzly] #2763226
04/12/20 11:14 PM
04/12/20 11:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think the nut maybe a left handed thread.
Re: Magnum threaded fan mount extension?? [Re: jbc426] #2764328
04/15/20 04:49 PM
04/15/20 04:49 PM
West Coast, USA
jbc426 Offline OP
jbc426  Offline OP
West Coast, USA
I think I found an extension, and ordered it. They use them on diesel rigs. I'll know soon enough if it fits my needs. I need just enough room to clear a 10 rib blower belt and not enough to push the fan too close to the radiator.
