Looking For "J Tube" Jet extensions #2758934
04/02/20 02:25 PM
04/02/20 02:25 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi All.
A few years ago I bought some of the above now I can't seem to find any anywhere online.
Anyone have any clues where to get them from?
Thanks and stay safe up
Re: Looking For "J Tube" Jet extensions [Re: Tig] #2759222
04/03/20 02:07 AM
04/03/20 02:07 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Re: Looking For "J Tube" Jet extensions [Re: Tig] #2759226
04/03/20 02:18 AM
04/03/20 02:18 AM
I've never seen or heard of these parts, what do they do? Where do they go into?
Re: Looking For "J Tube" Jet extensions [Re: Cab_Burge] #2759231
04/03/20 03:26 AM
04/03/20 03:26 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
According to the ad.......
" J-tubes are for dual four barrel carburetors mounted sideways. Their ID is 0.125". Price is for a set of four. "
Re: Looking For "J Tube" Jet extensions [Re: tubtar] #2759247
04/03/20 06:56 AM
04/03/20 06:56 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Jet extensions for sideways mounted carbs.
Re: Looking For "J Tube" Jet extensions [Re: Cab_Burge] #2759505
04/03/20 02:23 PM
04/03/20 02:23 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Fit over the front (fwd of the pair) jet on sideways mounted Holleys, the tube keeps the jet supplied with fuel when it wheelstands for a while up
Re: Looking For "J Tube" Jet extensions [Re: Tig] #2759522
04/03/20 03:04 PM
04/03/20 03:04 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Interesting, not what I expected...
I remember seeing something years ago about quick-change jets that were accessible through plugs in the top of the fuel bowl, so no gas escaped when changing them. That had to have a right-angle fitting of some type screwed into the metering block too. Is there still such a part? work
Re: Looking For "J Tube" Jet extensions [Re: DrCharles] #2759570
04/03/20 05:41 PM
04/03/20 05:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
BLP Rapid Jet.....
Re: Looking For "J Tube" Jet extensions [Re: Thumperdart] #2759596
04/03/20 06:58 PM
04/03/20 06:58 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That looks neat (a whole metering block with top-replaceable jets), but what I'm thinking of is decades older...
Must have been a right-angle fitting with male 1/4-32 threads to screw into the original metering block, and of course female threads for the stock Holley jets.
Re: Looking For "J Tube" Jet extensions [Re: DrCharles] #2759701
04/04/20 03:53 AM
04/04/20 03:53 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
These of course are the ultimate bowls and metering blocks for sideways mount up
dambest.com/catalog/product_info.php?products_id=100
Re: Looking For "J Tube" Jet extensions [Re: DrCharles] #2759813
04/04/20 12:59 PM
04/04/20 12:59 PM
Washington
hemienvy Online content
hemienvy  Online Content
Washington
Dr., Are you thinking of Percy's ?
Re: Looking For "J Tube" Jet extensions [Re: hemienvy] #2759906
04/04/20 02:27 PM
04/04/20 02:27 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That's not it either, but thanks for the info! Looks like a neat idea.
What I recall is something like the quick change float bowl but with the plugs in the top, and the jets oriented vertically in an adapter fitting.
Maybe I'm just conflating different memories shruggy
Anyway once I get my jets set close enough for street fun I probably won't need to change them very often, if at all.
Re: Looking For "J Tube" Jet extensions [Re: DrCharles] #2759924
04/04/20 02:42 PM
04/04/20 02:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Sounds like the Weber Power Plates.
Re: Looking For "J Tube" Jet extensions [Re: fast68plymouth] #2759999
04/04/20 03:12 PM
04/04/20 03:12 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Does anyone data log to be able to show before and after?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Looking For "J Tube" Jet extensions [Re: hemi-itis] #2760236
04/05/20 06:54 AM
04/05/20 06:54 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
For the J tubes? Before we fitted them along with the wedged floats, we would get a massive bog as the car tried to wheelie, Showed up as a lean spike on the log but we were only logging basic parameters and O2 ( L & R).
