Banana groove small block rocker shafts #275924
04/03/09 12:56 PM
04/03/09 12:56 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Can anyone explain how to do this or have pictures of this? I’m putting in a solid roller and was told that I should banana groove my shafts to deal with the added spring pressures.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Banana groove small block rocker shafts [Re: FlyFish] #275925
04/03/09 02:36 PM
04/03/09 02:36 PM
I believe with a small triangular file. I have not done it yet but I plan to I just need to find an orig banana grooved shaft so I can duplicate the angle/depth but I dont it has to be exact just so it will spread the oil out more on the load bearing surface
Re: Banana groove small block rocker shafts [Re: FlyFish] #275926
04/03/09 03:46 PM
04/03/09 03:46 PM
Bellevue WA
360ChallengerB3 Offline
Bellevue WA
I learned about it in a Mopar Muscle article:
360 Budget Rebuild: Double Take 360 Pt. 1 December 1999
360 Budget Rebuild: Double Take 360 Pt. 2
January 2000
360 Budget Rebuild: Double Take 360 Pt. 3 February 2000
Just cut a grove in the rocker shaft at a 45 degree angle centered on the oil hole. I don't remember if it gave specifics on depths or lengths.
Re: Banana groove small block rocker shafts [Re: FlyFish] #275927
04/03/09 07:45 PM
04/03/09 07:45 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Dremel tool works great..
Re: Banana groove small block rocker shafts [Re: Bill MeLater] #275928
04/03/09 08:48 PM
04/03/09 08:48 PM
Maryland
dduster73 Offline
dduster73  Offline
Maryland
Hughes engines sells them. Maybe you could find a picture of one on their website. Dave
Re: Banana groove small block rocker shafts [Re: FlyFish] #275929
04/03/09 09:35 PM
04/03/09 09:35 PM
MA
ragtop Offline
ragtop  Offline
MA
If you have access to a Bridgeport, Use a ball end mill.
Re: Banana groove small block rocker shafts [Re: ragtop] #275930
04/04/09 12:07 AM
04/04/09 12:07 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Cutoff wheel
Re: Banana groove small block rocker shafts [Re: FlyFish] #275931
04/04/09 09:56 AM
04/04/09 09:56 AM
SE PA
Born2Run Offline
Born2Run  Offline
SE PA
Re: Banana groove small block rocker shafts [Re: dart4forte] #275932
04/04/09 10:06 AM
04/04/09 10:06 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Cutoff wheel
thats what i used when i did it. but still it wasnt easy.
Rocker Arm Specialist can do it for you too. Plus they sell the arms already grooved (but the original mopars ones they sell now arent cheap)
Re: Banana groove small block rocker shafts [Re: Born2Run] #275933
04/04/09 10:41 AM
04/04/09 10:41 AM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
So, it looks like a small cut off wheel at an angle will do it right? Does anyone know why the groves are at an angle as apposed to parallel with the shaft?
Re: Banana groove small block rocker shafts [Re: FlyFish] #275934
04/04/09 12:39 PM
04/04/09 12:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
So that the oil will have a tendency to drain of onto the shaft rather than lay in the groove. Also the angle will make the groove slightly longer under the rocker than a straight across groove. Make sure to smooth any burrs that the wheel leaves on the edges of the groove while cutting.
