Banana groove small block rocker shafts
#275924
04/03/09 12:56 PM
04/03/09 12:56 PM
Posts: 1,178 Indy
FlyFish
Indy
Can anyone explain how to do this or have pictures of this? I’m putting in a solid roller and was told that I should banana groove my shafts to deal with the added spring pressures.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Banana groove small block rocker shafts
[Re: FlyFish]
#275925
04/03/09 02:36 PM
04/03/09 02:36 PM
RapidRobert
I believe with a small triangular file. I have not done it yet but I plan to I just need to find an orig banana grooved shaft so I can duplicate the angle/depth but I dont it has to be exact just so it will spread the oil out more on the load bearing surface
[Re: FlyFish]
#275931
04/04/09 09:56 AM
04/04/09 09:56 AM
Posts: 216 SE PA
Born2Run
SE PA
[Re: dart4forte]
#275932
04/04/09 10:06 AM
04/04/09 10:06 AM
Posts: 15,491 the boonies
aarcuda
the boonies
Cutoff wheel
thats what i used when i did it. but still it wasnt easy.
Rocker Arm Specialist can do it for you too. Plus they sell the arms already grooved (but the original mopars ones they sell now arent cheap)
[Re: Born2Run]
#275933
04/04/09 10:41 AM
04/04/09 10:41 AM
Posts: 1,178 Indy
FlyFish
Indy
So, it looks like a small cut off wheel at an angle will do it right? Does anyone know why the groves are at an angle as apposed to parallel with the shaft?
