Stock 340 six pack dyno test #2757551
03/30/20 11:25 AM
03/30/20 11:25 AM
Home
SRT6776 Offline OP
I hate internal combustion engines!
SRT6776  Offline OP
Home
Re: Stock 340 six pack dyno test [Re: SRT6776] #2757565
03/30/20 12:13 PM
03/30/20 12:13 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
I just watched this vid last week. thumbs
Pretty close to what NHRA factored them at.
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: Stock 340 six pack dyno test [Re: FM3AAR] #2757567
03/30/20 12:25 PM
03/30/20 12:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sure has a nasty bog.
Re: Stock 340 six pack dyno test [Re: SRT6776] #2757601
03/30/20 02:01 PM
03/30/20 02:01 PM
I don't know how much true compression ratio they made that motor have, stock from the factory OEM,not blue printed, they would have had around 9.5 to 1 or lower. shruggy
If you use the NHRA factory blue print specs provided by Ma Mopar to NHRA they will have around 11.3 to 11.6 to compression ratio shock
I use to race in NHRA Stock in division 7 in SO CA, I built two 1971 340 motors for Steve and Linda Meyers, one motor had the early X heads(894) and the other one had the mid 1970 J or U "916"heads, CRS now. Both motors had the same carb and intake, we tested several different ones of both and kept and used the best ones for both race motors, same grind camshaft degree in the same on both motor, I had moved it from 2 degrees retarded to 6 degrees advance. We had tested two other camshafts and tested them the same way, from 2 degrees retarded to 6 degrees advanced. The X headed motor made peak HP of 430 at 5900 RPM and the other motor with the J or U headed motor made 420 HP with the pistons hitting the eye brow around the valve seats on the heads, which is one of the problems when using those heads.
On this six pack motor with lower compression it should make at least 340 to 360 HP at 5500 RPM tune correctly on todays pump gas up twocents
BTW, I shut it, his video, off after the first pull before he started tuning it, as far as the bog when opening the outer carbs that is not hard to fix, raised the float levels to cure it up
Re: Stock 340 six pack dyno test [Re: Cab_Burge] #2757779
03/30/20 09:08 PM
03/30/20 09:08 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
The 70 340 4bbl video he did had 340 hp stock rebuild .030 bored . I expected more from the 6bbl.
Re: Stock 340 six pack dyno test [Re: formula_s] #2757789
03/30/20 09:35 PM
03/30/20 09:35 PM
New York
rarefish Offline
rarefish  Offline
New York
Anyone one else notice that the oil pressure went over 100 psi on each pull.
Also there was no manifold vacuum indication on the screen. I guessing for some reason, they never hooked up the vacuum input signal to the dyno.
Re: Stock 340 six pack dyno test [Re: stumpy] #2757800
03/30/20 09:50 PM
03/30/20 09:50 PM
New York
rarefish Offline
rarefish  Offline
New York
Yeah, The motor leans out when the outboards start to open as there is a monetary lag before the fuel starts to flow out of the boosters.
He needs to slow down the secondary opening a little with heavier springs in the pods.
Re: Stock 340 six pack dyno test [Re: rarefish] #2757816
03/30/20 10:55 PM
03/30/20 10:55 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
If you slow the outboard carb opening under these dyno or on road cruise conditions, there is a good chance that you'll slow the car down at the track.
Re: Stock 340 six pack dyno test [Re: rarefish] #2757817
03/30/20 10:57 PM
03/30/20 10:57 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
He could cut 10 to 20 minutes off his videos by not repeating himself so many times. Man this guy is hard to listen to.
Have to wonder what the owner is thinking giving a 30 over, numbers matching engine to this Wanna-be Youtube star for dyno beating?
356 hp 340 6 Pack
Mo' Farts
Moderated by "tbagger".
Re: Stock 340 six pack dyno test [Re: Grizzly] #2757825
03/30/20 11:34 PM
03/30/20 11:34 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
He mentioned that is why he only made 3 pulls.
Re: Stock 340 six pack dyno test [Re: formula_s] #2757828
03/30/20 11:58 PM
03/30/20 11:58 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
That's 3 chances I would absolutely not take with a my 6 figure T/A or AAR. twocents
Mo' Farts
Re: Stock 340 six pack dyno test [Re: Grizzly] #2757840
03/31/20 12:31 AM
03/31/20 12:31 AM
Home
SRT6776 Offline OP
SRT6776  Offline OP
Home
Your little article made the same power as he did
"On factory claims of 275 horsepower at 5,500 rpm and 340 lb-ft (3,200 rpm), we got 320 horsepower. Then we replaced the manifolds with a set of headers and got 352.1 horsepower"
They didn't push it for obvious reasons.
Re: Stock 340 six pack dyno test [Re: Grizzly] #2757846
03/31/20 12:48 AM
03/31/20 12:48 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
By watching the boosters it seems the air flow could be helped with two Stub Stacks like these:
https://pitstopusa.com/c-132427-air...nents-carburetor-airlflow-directors.html
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Stock 340 six pack dyno test [Re: SRT6776] #2758173
03/31/20 09:33 PM
03/31/20 09:33 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Didn't read the whole thing did you?
"Going back to the factory stock cast-iron exhaust manifolds, a Six Pack replaced the four barrel and we got 356 horsepower at 5,500 rpm and 382 lb-ft at 4,000 rpm"
Mo' Farts
