what size you think??? #275744
04/03/09 08:04 AM
04/03/09 08:04 AM
Illinois
moparmattkos Offline OP
mopar addict
mopar addict
Illinois
What size do you guys think roughly the chamber size is on a set of 516 closed chamber big block heads that been milled .020??? im guessin in the 75cc range ???
www.sikosracing.net Heads up Drag racing
Re: what size you think??? [Re: moparmattkos] #275745
04/04/09 09:21 AM
04/04/09 09:21 AM
Illinois
mopar addict
mopar addict
Illinois
Re: what size you think??? [Re: moparmattkos] #275746
04/04/09 09:49 AM
04/04/09 09:49 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I ran a set of basically stock 915's {simular to the 516's} on my 440 cu in Coronet with Ferrea valves and no porting done at all. The car {3050 lbs} ran a 10.99 in Seattle {best}
heres a chart on flow I found
here's a good article on heads
typical factory chamber volume of 78.5 cc your probably pretty close, CC them and know for positive.
Re: what size you think??? [Re: moparmattkos] #275747
04/04/09 12:20 PM
04/04/09 12:20 PM
Cab_Burge Online work
Cab_Burge  Online Work
80 to 83 CC Best way to make sure is to check it, you can go to a drugstore or a veterian supply like a big feed store and buy a large syringe and check it that way
Re: what size you think??? [Re: Cab_Burge] #275748
04/04/09 01:05 PM
04/04/09 01:05 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
my 915s were 82.
Re: what size you think??? [Re: RemCharger] #275749
04/04/09 01:20 PM
04/04/09 01:20 PM
Nebraska
Lime446 Offline
Lime446  Offline
Nebraska
Well since it's blizzarding here and no races now I killed some time and checked 2 516 heads.Both stock valves no milling. One was 81.5 and the other was 83 so milling .020 depending on valves and valve job I'm gonna say 78 ccs at best
FREE SNOW TO GIVE AWAY!!
