Page 1 of 3 1 2 3
Need good alignment specs*** UPDATE*** #275627
04/02/09 11:35 PM
04/02/09 11:35 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
For street and strip. I cant find my specs that i use for my cuda and its been over 10 years since its been aligned.
i thought it was something like 2 or 3 negative camber and 1/8" toe in.
anyone have some good numbers for a mixture of curves and straights?
im getting it aligned tomorrow
Re: Need good alignment specs [Re: aarcuda] #275628
04/02/09 11:47 PM
04/02/09 11:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
As much caster as you can get up to about 5 degrees positive
.5 to .75 negative camber with radial.
1/16 toe in.
Re: Need good alignment specs [Re: aarcuda] #275629
04/02/09 11:47 PM
04/02/09 11:47 PM
I set my ride height ahead of time after once it came back too low, 0 camber, as much positive caster as they could get(but the same amt on each side) forgot the toe in but iirc 1/16" to 1/8", all with my weight in barbells in the drivers seat after I get there, the tire psi where I want it, a half tank of gas, also told him to tighten the uca cam bolts TIGHT when he's done(the 65 lbs spec is too low) & a $20 tip for him to get it where I want it. My 65 dart tracks perfect
Re: Need good alignment specs [Re: RapidRobert] #275630
04/02/09 11:53 PM
04/02/09 11:53 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
probably should mention that ive got the Stage Three Firm Feel kit in my Fast Ratio TA power steering box right now and the steering is plenty stiff
Re: Need good alignment specs [Re: aarcuda] #275631
04/03/09 12:46 AM
04/03/09 12:46 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The increased caster will help the high spead stability and return to center effect. Steering ratio and/or box firmness will not do that.
Just to note, the fast ratio arm itself will add stiffness/less boost effect because of the leverage of the longer arm. That's on top of the decreased boost of a Stage 1,2,3 that comes from the changing the reaction springs in the steering box internals.
Re: Need good alignment specs [Re: autoxcuda] #275632
04/03/09 08:21 AM
04/03/09 08:21 AM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
well im going to do it. it will be nice to have my steering wheel point straight ahead again
Re: Need good alignment specs [Re: aarcuda] #275633
04/04/09 10:24 AM
04/04/09 10:24 AM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
well i got it aligned but im not to happy with the results.
Before it was really screwed up
caster -1.7 1.2
camber -.7 -.6
toe .25" .15"
After measurments were the best compromise
caster 2.5 3.2
camber .2 .2
toe .15" .10"
I was driving it home and on a back road the steering wheel and column was JUMPING up and down pretty several every now and then.
He couldnt give me any negative camber without screwing up the positive caster.
so, WHY was the steering wheel JUMPING?
If the spec says 1/16" toe, is that per wheel? or total between the two? it seems like .15" LEFT and .10" RIGHT would be .25" toe. is it?
Do I need tubular control arms to get this right?
I want the best cornering and the best straight away and best high speed stability.
Re: Need good alignment specs [Re: aarcuda] #275634
04/04/09 10:29 AM
04/04/09 10:29 AM
Kirkland, Washington
Pacnorthcuda Offline
The way you list the toe would lead me to believe you have .25 which is way too much. Toe is usually expressed as a single number, and yes its the relationship of one wheel to the other.
You now have postive camber.....hummmmm. I would have sacrificed whatever amount of caster was required to get you to 0 camber.
Rather that new UCA's the Moog offset bushings will remedy the problem nicely.
Jumping up and down.....not sure---maybe the excessive toe????
Re: Need good alignment specs [Re: aarcuda] #275635
04/04/09 12:13 PM
04/04/09 12:13 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
you really should have specified that caster be equal on each side not just as much as possible. my last alignment was like that and i was really unhappy with the way it tracked and handled. better to have 1.5 caster per side than more but unequal. i bet you can't let go of the wheel on a straightaway without the car drifting.
Re: Need good alignment specs [Re: dirtybee] #275636
04/04/09 12:19 PM
04/04/09 12:19 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
unequal caster will cause a car to pull and "follow" the road differently on one side vs the other...
I would want to see the caster the same on both sides.
Also, I forget the convention but the camber you want is with the wheel pointed slightly outward (ie so it wares the inside of the tire - I think this is right...
Re: Need good alignment specs [Re: Pacnorthcuda] #275637
04/04/09 06:39 PM
04/04/09 06:39 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
He took what you wanted to literally. Or he didn't understand the concepts enough to know the order of importance and minimum levels of the specs/requests you asked him.
I think you might need to find a better alignment shop. That or something is really lacking in communication.
-Adjust the caster to the greatest amount with rear cam adjuster all the way inward and front all the way outward.
-Then bring in front adjuster to get to at least 0 or .25 negative camber.
-Then do the same for the other side.
-Then go to the side with the most caster and adjust the front cam adj. inward so the caster is about halfway toward the other side's number.
-Then adjust the rear cam adj. out enough to get the camber match other other side.
That should get you pretty close. Then you have to go back and forth with the front a rear adjuster to get the camber and caster to match the other side.
The camber should be a minimum of 0 or .25 NEGATIVE (top of tire in).
The reason it pulled before is that the car had cross caster. One side was negative (-1.7) and the other side was positive (1.2).
Re: Need good alignment specs [Re: RapidRobert] #275638
04/04/09 10:51 PM
04/04/09 10:51 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
If I cannot do it, I ask the alignment guy what the first step to a Mopar torsion bar suspension alignment is. If he doesn't say set ride height, I move on.
There used to be the disclaimer: torsion bar suspensions extra on alignment prices because of the extra step.
Craig
Re: Need good alignment specs [Re: denfireguy] #275639
04/04/09 10:59 PM
04/04/09 10:59 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Alignments can be done properly at different ride heights. Mopar was the only one that allowed a height adjustment. Granted mopar has specs with ride height setting to make bump steer a minimum.
As far as ride height goes all cars should be adjusted at the factory recommended height. I always made sure the right to left was even and the car was not nosed up or down at a bad angle.
Re: Need good alignment specs [Re: autoxcuda] #275640
04/04/09 11:20 PM
04/04/09 11:20 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
I assume you are using teh degree plate to measure the degree of turn on the wheels as you measure caster. Wha degree are you turning to? 20 degree? 30 degree? I would be interested in knowing this. Thanks.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: Need good alignment specs [Re: RTDaddy] #275641
04/05/09 02:45 AM
04/05/09 02:45 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If you are doing it on some sort of modern alignment rack the machine will tell you the angle or set point.
A Longacre caster camber gauge can use a degree plate, but there is also an angle machined on the edge of the gauge. You turn the wheel until the angle is paralell to the car. OR mark the rotations on the steering wheel (tape mark on wheel) and make sure the wheel is turned the same exact amount both ways from center.
Re: Need good alignment specs*** UPDATE*** [Re: aarcuda] #275642
04/05/09 09:34 AM
04/05/09 09:34 AM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
I am installing Bondo Bob upper arms on my challenger this weekend.
Setting up with a magnetic longacre caster camber guage.
I first set he ride height. I use the adjusting screw on each lower control arm to set not only the front ride height, but this adjustment will even out the rear ride height as well. Note: the screws are no where to equeal on each side, at least 10 threads different left to right. perhaps due to hex socket on torsion bar not welded to frame clocked even?
I set he camber on both front wheels to about -.625 deg. with the front end pushed down. If the front end of the car is lifted up to rest I get -.375 deg. camber. if I jack the car up 1" to simulate running down the track, camber is about 0.
Testing the caster drivers side reads +3.5 deg
passenger side reads +7.5 deg .I set the Bondo bob arms with 4 threads showing on the front heim a no threads showing on the rear heim.
I am going to have to adjust the passenger side heim joints on the upper arm to try to match the drivers side 3.5 deg positive setting.
I highly recomend a longacre type guage.
Re: Need good alignment specs*** UPDATE*** [Re: ToddP] #275643
04/05/09 10:22 AM
04/05/09 10:22 AM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
How do you use this gauge, I can not see a good way to attach it to the wheel? Most wheels do not have a machined flat serface to attach the gauge to...
What do you guys do...
I bought the Fasxtracks one with the 3 arms that contact the rim edge...
Re: Need good alignment specs*** UPDATE*** [Re: 6T6Cuda] #275644
04/05/09 11:10 AM
04/05/09 11:10 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
aarcuda, Where do you live?
If your close enough I'll set the car up for ya.
Re: Need good alignment specs*** UPDATE*** [Re: 6T6Cuda] #275645
04/05/09 12:18 PM
04/05/09 12:18 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
I take the press on cap off, the cotter pin off and the cotter pin retainer off. the magnetic base then rests on the brake rotor. I had to use a shorter head on the bolt that holds the magnetic base to the guage.
Re: Need good alignment specs*** UPDATE*** [Re: WILD BILL] #275646
04/05/09 09:08 PM
04/05/09 09:08 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
not very close. im in Arkansas.
my alignment guy isnt a a total idiot. he tried to get me what I asked for. but said that if he adjusts the canmber to negative, my caster goes all to hell. then we talked about what he could get me for camber if he set the caster to 2.5/3.5 and let me know that I'd be at positive camber.
me, not knowing anything said go ahead and go for as much - camber yu could at 2.5/3.5 and thats what he did.
if i'd have known the -camber was that important, i could have had him set it there. i'll also ask [Edited by Moparts - Keep it clean] is up with the toe numbers and get them straightened out
I'll take the car back there and have him try that. he's giving me a buddy deal so its not costing all that much.
the good news is that the car seems to drive fine. i guess that jumping i felt in the wheel must have been the road cause i havent felt it again. I drove a good 100 miles or so this weekend and ran it down the track and it felt fine in the corners (although i did squeek a little doing some cornering at faster than normal speed- i guess thats the + camber coming back to haunt me) and it felt fine at the drag strip.
Page 1 of 3 1 2 3
