Headers And Mini Starters
#2754077
03/21/20 08:50 AM
03/21/20 08:50 AM
Posts: 1,001 Canada
Ghoste
Canada
Ive been looking online and all I find is older information. Looking for actual experiences from people with a 440 and a four speed with a Lakewood bellhousing over a 143 tooth flywheel and the 11 inch clutch and headers in a 69 B-body. What is a header and starter combination that actually works? A little frustrated here because in 50 years, there is no way I am the first guy to have this issue. Did they stop making proper headers for this combination? How was it done before? Experiences with 340 A body cars are no use to me and dont bother with suggestions of how great the Dakota starter fits. I have a 69 Charger with the big flywheel and Hedman headers (yes they are a poor fitting brand) and I am telling you, the clever fits all with no problem mini starter absolutely does NOT fit. Not even close. Junkyard one, NAPA one, Chrysler one, Mancini. The mini starter DOES NOT FIT THIS COMBINATION. Robbmc says theirs "usually" does with "some" TTI headers. That is a lot of money to dish out for usually and some so that is why I am looking for apple to apple experiences.
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
Re: Headers And Mini Starters
[Re: Ghoste]
#2754276
03/21/20 05:46 PM
03/21/20 05:46 PM
Posts: 2,126 Mobile Al
hemirdrnnr
Mobile Al
Ive been looking online and all I find is older information. Looking for actual experiences from people with a 440 and a four speed with a Lakewood bellhousing over a 143 tooth flywheel and the 11 inch clutch and headers in a 69 B-body. What is a header and starter combination that actually works? A little frustrated here because in 50 years, there is no way I am the first guy to have this issue. Did they stop making proper headers for this combination? How was it done before? Experiences with 340 A body cars are no use to me and dont bother with suggestions of how great the Dakota starter fits. I have a 69 Charger with the big flywheel and Hedman headers (yes they are a poor fitting brand) and I am telling you, the clever fits all with no problem mini starter absolutely does NOT fit. Not even close. Junkyard one, NAPA one, Chrysler one, Mancini. The mini starter DOES NOT FIT THIS COMBINATION. Robbmc says theirs "usually" does with "some" TTI headers. That is a lot of money to dish out for usually and some so that is why I am looking for apple to apple experiences. What problem are you having exactly????
[Re: hemirdrnnr]
#2754293
03/21/20 06:51 PM
03/21/20 06:51 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Like Gus I have a lakewood 143 2 inch old TTIs on my 440 65 Belvedere.Run a mini for a 98 Durango with 360.Been in there since 2000.Still goes strong.Did have to cut down the elect studs a bit after removing the goffy connector that they used.Its a pain to get to and have to undo the headers to get it in and out.I run a insulated sleeve on the cables going to it also.Rocky
Chrysler Firepower
[Re: RobbMc]
#2754948
03/23/20 11:01 AM
03/23/20 11:01 AM
Posts: 5,164 CT
GTX MATT
CT
I have a '67 but everything relevant is the same. A stock starter or a late model Ram (I think I used a 92 W250 with a 360) mini-starter both work with Hooker 5903 headers. The stock starter is harder to get everything together with, I think I pulled the steering column to make it easier when I installed it.
