Threaded Plug #2753520
03/19/20 03:59 PM
03/19/20 03:59 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Under the 440 fuel pump for removing the push rod. Is it suppose to sit flush with the block? Goes about 1/2 way and gets real tight.
Grandma always said I had "hands of gold"!
Re: Threaded Plug [Re: CHRGR69] #2753535
03/19/20 04:33 PM
03/19/20 04:33 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
don't worry... is ok.
I think block is conical threated to seal good so just reach up to where is posible
Re: Threaded Plug [Re: CHRGR69] #2753554
03/19/20 05:17 PM
03/19/20 05:17 PM
Mopar had some short NPT plugs for that fuel pump hole, regular NPT long ones work okay also up
I may have had to grind off one of the outer edge off of one or more to make sure the bottom edge of the fuel pump bodies wouldn't touch the plugs scope
Re: Threaded Plug [Re: Cab_Burge] #2753589
03/19/20 06:38 PM
03/19/20 06:38 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
it's a tapered pipe thread. I wouldn't be concerned as long as it's snug
Re: Threaded Plug [Re: CHRGR69] #2753614
03/19/20 07:42 PM
03/19/20 07:42 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Make sure to use a sealer and do not over tighten as previously mentioned. It is a tapered pipe plug and doing do can crack the block. beer
