1980 w150 , /6 - can’t resolve fast idle #2656400
05/17/19 09:49 PM
05/17/19 09:49 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Been trying to resolve fast / sticking idle issue
ALL SMOG CONTROLS TAKEN OFF BY PAST OWNER
As far as I can tell it’s the original carb
So far I have cleaned the fuel tank
New sending unit
New gas cap
New fuel line front to back
New fuel filter
New carb base gasket (check for leaks with flammable spray)
Cleaned carb twice
All unused vacuum ports capped with NEW caps
Installed distributor properly
Plug wires installed properly
Timing set at 8* btdc at idle
Idle air adjustment done as best I can by ear.
The only issue I can come up with is it seems the plastic accelerator pump body kinda hangs up on its retainer
Any suggestions ? Maybe get older carb pre-smog ?
Thanks !
Re: 1980 w150 , /6 - can’t resolve fast idle [Re: lostdog] #2656419
05/17/19 10:35 PM
05/17/19 10:35 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Choke linkage adjusted correctly. It can keep the fast idle cam up.
Re: 1980 w150 , /6 - can’t resolve fast idle [Re: stumpy] #2656423
05/17/19 10:39 PM
05/17/19 10:39 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
The choke linkage isn’t even connected. The actuating Rod is all jacked up and bent so I wouldn’t even know what it’s supposed to look like. Can you tell me how to correct it ?
Re: 1980 w150 , /6 - can’t resolve fast idle [Re: lostdog] #2656426
05/17/19 10:53 PM
05/17/19 10:53 PM
Grand Prairie,Texas
Grand Prairie,Texas
Re: 1980 w150 , /6 - can’t resolve fast idle [Re: stumpy] #2656435
05/17/19 11:32 PM
05/17/19 11:32 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Thank you !!
Re: 1980 w150 , /6 - can’t resolve fast idle [Re: lostdog] #2750730
03/10/20 12:11 PM
03/10/20 12:11 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
How's the slop in the throttle shaft? The butterfly can hang up. Get vacuum leaks around the shaft too.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 1980 w150 , /6 - can’t resolve fast idle [Re: Rug_Trucker] #2750998
03/11/20 01:18 PM
03/11/20 01:18 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Does that one have the idle kicker solenoid? My kid's 80 does, same truck and same engine in 2wd form.
Re: 1980 w150 , /6 - can’t resolve fast idle [Re: volaredon] #2751480
03/13/20 09:58 AM
03/13/20 09:58 AM
scratchnfotraction Offline
make sure the weights in dist are not sticky. if the weights agummed up they are slow to return or stay advance which will idle up the engine.
open dist for cleaning and some fresh lube on weight pins.
add a set of the MrGasket mopar mech advance spring kit. use both springs for a fast mech a all in by 1200-1500 rpm
mark the damper to 32*-35* BFTC use timing light and rev engine till it is full advance and hold rpm adjust the mark to the 0* mark on timing tab. now you have total timing set.
let it idle and see where the 0* mark on damper lines up on timing tab. this is the initial timing or base timing.
next hook up the dist vac can to full vac port on carb and try it. vacuum advance may or may not be used as the light spring spins up to full advance at a low rpm
set you curb idle to where you want it
Re: 1980 w150 , /6 - can’t resolve fast idle [Re: scratchnfotraction] #2764788
04/16/20 08:19 PM
04/16/20 08:19 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Intake gasket/warped intake? Had this happen on my 86 d100.
