New with nitrous #2748707
03/03/20 07:04 PM
03/03/20 07:04 PM
Northeast
Racer68 Offline OP
Racer68  Offline OP
Northeast
This is my first nitrous post. Just had a motor built with two Dominators, Hogan intake and a wet nitrous system. Although I doubt I will be using any nitrous for a while, I’d like to wire it all in while setting up the rest of the car. I’ll be running a 200 horse max shot maybe even 150. What would be the best way for me to activate the system? I’ve been told that a wide open throttle switch on the carbs and an activation switch inside the car would be a good system.
Suggestions and opinions would be appreciated.
Re: New with nitrous [Re: Racer68] #2748728
03/03/20 08:02 PM
03/03/20 08:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Sorry
Boffin Emeritus
Re: New with nitrous [Re: Racer68] #2748753
03/03/20 09:23 PM
03/03/20 09:23 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
A micro switch on throttle works for a lot of people. I actually prefer a button on the shifter to activate the system.
Look at Leash Electronics. They make a lot of great products that make wiring and control much easier!
'63 Dodge 330
11.19 @ 121 mph
Re: New with nitrous [Re: Racer68] #2748791
03/03/20 11:16 PM
03/03/20 11:16 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
is this a big or small tire car?
A grid or other "programable ignition will be great to pull timing and control the hit at first launch
Progressive is a good idea, but any decent chassis should be able to handle a 200-150 hit, or just timing should be able to calm it.
Yes throttle switch is best bet, if using a transbrake you can wire a relay to interupt the throttle switch when the brake is activated.
....BAD A$$ STREET CAR.....
Re: New with nitrous [Re: n20mstr] #2748871
03/04/20 10:23 AM
03/04/20 10:23 AM
an8sec70cuda Offline
iagree I prefer a WOT switch after having done it many different ways now. I also highly recommend Leash Electronics' products.
For just a 150-200 hit, depending on your car...you should be fine w/ just a timer if you wanted some ability to control when it comes in w/o spending the money on a progressive.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New with nitrous [Re: n20mstr] #2748934
03/04/20 01:58 PM
03/04/20 01:58 PM
Northeast
Racer68 Offline OP
Racer68  Offline OP
Northeast
Yes, this is a big tire car. And I’m also running the MSD grid module so maybe I could tie it together so it pulls timing out of the motor?
Thanks for the responses.
Re: New with nitrous [Re: Racer68] #2748952
03/04/20 02:37 PM
03/04/20 02:37 PM
Pretty sure you can do everything you need w/ the Grid.
CHIP
