Re: New with nitrous
[Re: Racer68]
#2748753
03/03/20 09:23 PM
03/03/20 09:23 PM
Posts: 4,672 Wichita
GY3
Wichita
H This is my first nitrous post. Just had a motor built with two Dominators, Hogan intake and a wet nitrous system. Although I doubt I will be using any nitrous for a while, I’d like to wire it all in while setting up the rest of the car. I’ll be running a 200 horse max shot maybe even 150. What would be the best way for me to activate the system? I’ve been told that a wide open throttle switch on the carbs and an activation switch inside the car would be a good system. Suggestions and opinions would be appreciated. A micro switch on throttle works for a lot of people. I actually prefer a button on the shifter to activate the system. Look at Leash Electronics. They make a lot of great products that make wiring and control much easier!
[Re: Racer68]
#2748791
03/03/20 11:16 PM
03/03/20 11:16 PM
Posts: 4,677 On the parachute mount
n20mstr
This is my first nitrous post. Just had a motor built with two Dominators, Hogan intake and a wet nitrous system. Although I doubt I will be using any nitrous for a while, I’d like to wire it all in while setting up the rest of the car. I’ll be running a 200 horse max shot maybe even 150. What would be the best way for me to activate the system? I’ve been told that a wide open throttle switch on the carbs and an activation switch inside the car would be a good system. Suggestions and opinions would be appreciated. is this a big or small tire car? A grid or other "programable ignition will be great to pull timing and control the hit at first launch Progressive is a good idea, but any decent chassis should be able to handle a 200-150 hit, or just timing should be able to calm it. Yes throttle switch is best bet, if using a transbrake you can wire a relay to interupt the throttle switch when the brake is activated.
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2748871
03/04/20 10:23 AM
03/04/20 10:23 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I prefer a WOT switch after having done it many different ways now. I also highly recommend Leash Electronics' products. For just a 150-200 hit, depending on your car...you should be fine w/ just a timer if you wanted some ability to control when it comes in w/o spending the money on a progressive.
[Re: n20mstr]
#2748934
03/04/20 01:58 PM
03/04/20 01:58 PM
Posts: 22 Northeast
Racer68
Northeast
This is my first nitrous post. Just had a motor built with two Dominators, Hogan intake and a wet nitrous system. Although I doubt I will be using any nitrous for a while, I’d like to wire it all in while setting up the rest of the car. I’ll be running a 200 horse max shot maybe even 150. What would be the best way for me to activate the system? I’ve been told that a wide open throttle switch on the carbs and an activation switch inside the car would be a good system. Suggestions and opinions would be appreciated. is this a big or small tire car? A grid or other "programable ignition will be great to pull timing and control the hit at first launch Progressive is a good idea, but any decent chassis should be able to handle a 200-150 hit, or just timing should be able to calm it. Yes throttle switch is best bet, if using a transbrake you can wire a relay to interupt the throttle switch when the brake is activated. Yes, this is a big tire car. And I’m also running the MSD grid module so maybe I could tie it together so it pulls timing out of the motor? Thanks for the responses.
[Re: Racer68]
#2748952
03/04/20 02:37 PM
03/04/20 02:37 PM
an8sec70cuda
Pretty sure you can do everything you need w/ the Grid.
