Oil pump interference #2744239
02/18/20 12:16 PM
02/18/20 12:16 PM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
Building a 74 Duster with a big block 451 stroker. Going to use the Schumacher conversion spool mount kit. I have a Melling High volume oil pump to use. Anyone know if there's any interference problem with the crossmember mount area using this pump? Or is it no problem?
Re: Oil pump interference [Re: superwrench] #2744280
02/18/20 02:14 PM
02/18/20 02:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Put a 383 in a 74 Scamp and the oil pump was not a problem.
Re: Oil pump interference [Re: stumpy] #2744286
02/18/20 02:42 PM
02/18/20 02:42 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I don't think the physical dimensions of the Melling HV pump are much different than the stock BB pump.
I don't have experience with the spool mounts personally, but as long as the height of the motor is the same as the stock mounts, the oil filter should be above the k-member.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Oil pump interference [Re: wingman] #2744335
02/18/20 04:29 PM
02/18/20 04:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I used the lager high volume high pressure pump which is longer than stock.
Re: Oil pump interference [Re: stumpy] #2744344
02/18/20 04:48 PM
02/18/20 04:48 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Remember the direct connection kit that was the taller rotor, a spacer plate, and couple gaskets....to piece together your own HV pump from a stocker? The kit wasn’t that much cheaper than a whole new HV pump.
Re: Oil pump interference [Re: Pacnorthcuda] #2744569
02/19/20 12:04 PM
02/19/20 12:04 PM
moparx Offline
moparx  Offline
i believe the difference is 1/4".
beer
Re: Oil pump interference [Re: moparx] #2744574
02/19/20 12:24 PM
02/19/20 12:24 PM
Looking at it, it's going to be close to the gusset that comes forward from the steering box area. I'll let you know how it turns out. Thanks guys....
Re: Oil pump interference [Re: Pacnorthcuda] #2744576
02/19/20 12:27 PM
02/19/20 12:27 PM
Missouri
randavis Offline
randavis  Offline
Missouri
I bought one of those in 1978. It is still running today. The spacer is 1/4". The stock pump rotor is 1" tall, the HV one is 1-1/4".
I had the engine apart last year and I replaced the gaskets and o-rings. The gasket set only comes with one of the large o-rings and I could not find any place selling just the large o-ring for the chrysler pump. I went to a local hydraulic rebuilder and they were able to get me one.
Edit:
The kit also came with the heavier releif spring IIRC. At that time I was using Valvoline racing 40 W oil. On a cold start, it would peg my 100 lb. mechanical oil gauge. It ran around 80 lb. hot above 2000 rpm, and idled at 60. I am now using VR-1 10-30 racing oil. It is 80 lb. cold and runs at 60 lb, ildles at 30 lb.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
