Re: Oil pump interference
[Re: stumpy]
#2744286
02/18/20 02:42 PM
02/18/20 02:42 PM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I don't think the physical dimensions of the Melling HV pump are much different than the stock BB pump.
I don't have experience with the spool mounts personally, but as long as the height of the motor is the same as the stock mounts, the oil filter should be above the k-member.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Pacnorthcuda]
#2744576
02/19/20 12:27 PM
02/19/20 12:27 PM
Posts: 141 Missouri
randavis
Missouri
Remember the direct connection kit that was the taller rotor, a spacer plate, and couple gaskets....to piece together your own HV pump from a stocker? The kit wasn’t that much cheaper than a whole new HV pump. I bought one of those in 1978. It is still running today. The spacer is 1/4". The stock pump rotor is 1" tall, the HV one is 1-1/4". I had the engine apart last year and I replaced the gaskets and o-rings. The gasket set only comes with one of the large o-rings and I could not find any place selling just the large o-ring for the chrysler pump. I went to a local hydraulic rebuilder and they were able to get me one. Edit: The kit also came with the heavier releif spring IIRC. At that time I was using Valvoline racing 40 W oil. On a cold start, it would peg my 100 lb. mechanical oil gauge. It ran around 80 lb. hot above 2000 rpm, and idled at 60. I am now using VR-1 10-30 racing oil. It is 80 lb. cold and runs at 60 lb, ildles at 30 lb.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
