Please, Help me pick a cam #274429
04/01/09 09:34 PM
04/01/09 09:34 PM
Hunt Valley, Maryland
1fastrunner Offline OP
I'm planning on using either the 509 cam or something very similar. Is MP the way to go, or should i be looking at other vendors?
Re: Please, Help me pick a cam [Re: 1fastrunner] #274430
04/01/09 09:54 PM
04/01/09 09:54 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
what are you going to do with the car?? if it's a driver you'll be un happy with the 509. i had it in my R/R with a4 sp and 391 didnt come alive till 1800- 2000. idle was huh ruff. my fiend runs the 484 and everyone i talked to drop down to the 484 and was happier. or go to a comp or a reed cam
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Please, Help me pick a cam [Re: hulmule] #274431
04/01/09 10:18 PM
04/01/09 10:18 PM
Washougal,Wa
Dodge Offline
Dodge  Offline
Washougal,Wa
I had a 509 in my 70 Cuda with a 440. It must not of had enough compression. It was a real dog. I put a Comp Cam XE274H and it was like night and day. Very happy. It pulls hard from the bottom rpms to top.
Stand behind your word
Re: Please, Help me pick a cam [Re: Dodge] #274432
04/01/09 10:21 PM
04/01/09 10:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you want a good street/strip cam and have around 10:1 compression I would definitely with either the Comp XE275HL or the Lunati Voodoo 60303 which is a few degrees milder than the aforementioned comp grind.
Re: Please, Help me pick a cam [Re: DaytonaTurbo] #274433
04/01/09 10:55 PM
04/01/09 10:55 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The 509 has for a long time been the mainstay of the MoPar big block performance machine. That being said its outdated, I'd run something from Hughes or Engle.
Re: Please, Help me pick a cam [Re: GTX MATT] #274434
04/02/09 12:03 AM
04/02/09 12:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It will realy depend on what you want in the car. Will it be a street/strip car or street only ?? The MP .509 will make great power for what it is in the right combo. But it has a nice lopey idle that is great if you like that and can live with it. And you need to run a good bit of gear and converter with the .509 along with at least 10.0 comp imo. In the right combo the .509 will scream but if your car is street only and you dont set the combo right to get low end with the .509 you wont like it. Street only as a driver and a nice idle then I would go with as stated the Comp ' Lunati , Hughes , Engle or Crane. Call the cam company and tell them the combo you are building so they can help you or get in touch with Dwayne Porter as he is very good with cams. Good luck , Ron
Re: Please, Help me pick a cam [Re: 383man] #274435
04/02/09 12:29 AM
04/02/09 12:29 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Call one of the Mopar engine shops, they will help you out.
We really do have some great Mopar shops around the country so it is hard to point you to just one.
I want my fair share
Re: Please, Help me pick a cam [Re: DaytonaTurbo] #274436
04/02/09 02:04 AM
04/02/09 02:04 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
The Lunati Voodoo cams sure make good street cams.
The Voodoo's are a step up from the BR. II's.
Snap your neck, mega G-force launch, is all I want!
Re: Please, Help me pick a cam [Re: 1fastrunner] #274437
04/02/09 03:38 AM
04/02/09 03:38 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The Mopar 484 and 509 cams were designed for bracket racing. Their good points are that they are cheap, relatively easy on valve springs, and make good mid/upper RPM power. The cons are they have a rough idle and weak low end power.
There are better cams avaliable that can make better power through a wider RPM range. They are a bit more expensive, and usually require using valve springs matched to the cam being used.
The Hughes cams are some of the most agressive profile flat tappet cams avaliable off the shelf.
The Comp HE2??HL cams are good too.
I think the Voodo cams are simular, but I have not used them.
Re: Please, Help me pick a cam [Re: 451Mopar] #274438
04/02/09 05:37 AM
04/02/09 05:37 AM
My car is a '71 Roadrunner w/ a 4-speed and 3.23 gears. It will be street driven.
Thanks,
Re: Please, Help me pick a cam [Re: 1fastrunner] #274439
04/02/09 07:22 AM
04/02/09 07:22 AM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
ive run the .484, .509 and the .528. if your useing a solid settup i would go with the .528 unit little less duration and still not to hard on things.
Re: Please, Help me pick a cam [Re: 1fastrunner] #274440
04/02/09 08:21 AM
04/02/09 08:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Thanks,
509 is a good cam for a 10:1+ motor, good heads, intake, headers and 3.91's or better. If you want to keep the 3.23's you'd probably be better off w/ a different cam. Something a little more low-ended.
Re: Please, Help me pick a cam [Re: Mr.Yuck] #274441
04/02/09 08:38 AM
04/02/09 08:38 AM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
The 484 works well with your combo. Nice low end torque and power across the board.
Re: Please, Help me pick a cam [Re: 1fastrunner] #274442
04/02/09 11:16 AM
04/02/09 11:16 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
what is the engine combination?
Are you just going to install the cam in the stock engine or are you rebuilding the motor?
Is that a 383 or 440? What pistons/compression ratio, heads and/or headwork? what intake and exhaust are you using?
Re: Please, Help me pick a cam [Re: 1fastrunner] #274443
04/02/09 01:04 PM
04/02/09 01:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thanks,
Definetly do not want to use the .509 cam in that combo. The MP stock bigblock cam would work nice in that. It has about .455 lift and .258 advertised I believe. Or just call Comp or Crane or whatever cam you decide on and let them help you. Ron
Re: Please, Help me pick a cam [Re: 451Mopar] #274444
04/02/09 02:17 PM
04/02/09 02:17 PM
It's a 440 30 over w/ Arias piatond (about 9.5), but that could change if the heads are planed. I want to maintain pump gas, it has a Holley 750 dp, and an Edelbrock chp4(?). Hooker super comps 1 78/" and a 2.5 exhaust, which will be upgraded to 3" in the future. I'd like to keep the 3.23 gears as I like to drive distances. The motor is being rebuilt.
I'm looking for the best cam for this set-up including the stealth heads.
Thanks,
Re: Please, Help me pick a cam [Re: 1fastrunner] #274445
04/02/09 02:29 PM
04/02/09 02:29 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
When you ask everyone with different opinions,this is what you get.
Re: Please, Help me pick a cam [Re: DaytonaTurbo] #274446
04/02/09 08:55 PM
04/02/09 08:55 PM
IN
ahy Offline
ahy  Offline
IN
With a manual trans street driven its loads of fun to have lots of torque on tap from 2000 to 5000 RPM. The 509 won't give you that - it has too much duration plus you can't run a loose convertor to compensate. A faster rate cam as posted above with enough lift to take advantage of your heads would work much better.
With the stealth heads, if you can get your piston to zero deck so the "quench" equals the .040 (approximate) thickness of the head gasket you can run more compression than 9.5. 10.25 would still be conservative and give more torque and power. If your piston is "down in the hole" then 9.5 or a little more is probably about right.
Re: Please, Help me pick a cam [Re: Airgrabber] #274447
04/02/09 09:07 PM
04/02/09 09:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
mopar 484? that will be a dog w/ 3.23's it's not much different than the 509. It pulls terrible vacuum and has poor street manners. The old grind anyway.
Re: Please, Help me pick a cam [Re: Mr.Yuck] #274448
04/02/09 09:44 PM
04/02/09 09:44 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
the 484 is gonna want gear. It is a racing cam.
not as bad as the 509. Which is a serious cam that is every bit as good as the cams today. Most modern cams are small base circle. If a thumping shaft is getting shoved in a mill hole, It better be thick and bumpy.
