Re: Please, Help me pick a cam
[Re: 1fastrunner]
#274430
04/01/09 09:54 PM
04/01/09 09:54 PM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
what are you going to do with the car?? if it's a driver you'll be un happy with the 509. i had it in my R/R with a4 sp and 391 didnt come alive till 1800- 2000. idle was huh ruff. my fiend runs the 484 and everyone i talked to drop down to the 484 and was happier. or go to a comp or a reed cam
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: hulmule]
#274431
04/01/09 10:18 PM
04/01/09 10:18 PM
Posts: 777 Washougal,Wa
Dodge
Washougal,Wa
I had a 509 in my 70 Cuda with a 440. It must not of had enough compression. It was a real dog. I put a Comp Cam XE274H and it was like night and day. Very happy. It pulls hard from the bottom rpms to top.
Stand behind your word
[Re: DaytonaTurbo]
#274433
04/01/09 10:55 PM
04/01/09 10:55 PM
Posts: 5,166 CT
GTX MATT
CT
The 509 has for a long time been the mainstay of the MoPar big block performance machine. That being said its outdated, I'd run something from Hughes or Engle.
[Re: GTX MATT]
#274434
04/02/09 12:03 AM
04/02/09 12:03 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
It will realy depend on what you want in the car. Will it be a street/strip car or street only ?? The MP .509 will make great power for what it is in the right combo. But it has a nice lopey idle that is great if you like that and can live with it. And you need to run a good bit of gear and converter with the .509 along with at least 10.0 comp imo. In the right combo the .509 will scream but if your car is street only and you dont set the combo right to get low end with the .509 you wont like it. Street only as a driver and a nice idle then I would go with as stated the Comp ' Lunati , Hughes , Engle or Crane. Call the cam company and tell them the combo you are building so they can help you or get in touch with Dwayne Porter as he is very good with cams. Good luck , Ron
[Re: 383man]
#274435
04/02/09 12:29 AM
04/02/09 12:29 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
Call one of the Mopar engine shops, they will help you out.
We really do have some great Mopar shops around the country so it is hard to point you to just one.
I want my fair share
[Re: 1fastrunner]
#274440
04/02/09 08:21 AM
04/02/09 08:21 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
My car is a '71 Roadrunner w/ a 4-speed and 3.23 gears. It will be street driven. Thanks, Jim
509 is a good cam for a 10:1+ motor, good heads, intake, headers and 3.91's or better. If you want to keep the 3.23's you'd probably be better off w/ a different cam. Something a little more low-ended.
[Re: 1fastrunner]
#274443
04/02/09 01:04 PM
04/02/09 01:04 PM
383man
Balt. Md
Definetly do not want to use the .509 cam in that combo. The MP stock bigblock cam would work nice in that. It has about .455 lift and .258 advertised I believe. Or just call Comp or Crane or whatever cam you decide on and let them help you. Ron
[Re: 451Mopar]
#274444
04/02/09 02:17 PM
04/02/09 02:17 PM
Posts: 2,126 Hunt Valley, Maryland
1fastrunner
It's a 440 30 over w/ Arias piatond (about 9.5), but that could change if the heads are planed. I want to maintain pump gas, it has a Holley 750 dp, and an Edelbrock chp4(?). Hooker super comps 1 78/" and a 2.5 exhaust, which will be upgraded to 3" in the future. I'd like to keep the 3.23 gears as I like to drive distances. The motor is being rebuilt. I'm looking for the best cam for this set-up including the stealth heads. Thanks, Jim
[Re: 1fastrunner]
#274445
04/02/09 02:29 PM
04/02/09 02:29 PM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
I'm planning on using either the 509 cam or something very similar. Is MP the way to go, or should i be looking at other vendors? Jim
When you ask everyone with different opinions,this is what you get.
[Re: DaytonaTurbo]
#274446
04/02/09 08:55 PM
04/02/09 08:55 PM
Posts: 7,664 IN
ahy
IN
If you want a good street/strip cam and have around 10:1 compression I would definitely with either the Comp XE275HL or the Lunati Voodoo 60303 which is a few degrees milder than the aforementioned comp grind.
With a manual trans street driven its loads of fun to have lots of torque on tap from 2000 to 5000 RPM. The 509 won't give you that - it has too much duration plus you can't run a loose convertor to compensate. A faster rate cam as posted above with enough lift to take advantage of your heads would work much better.
With the stealth heads, if you can get your piston to zero deck so the "quench" equals the .040 (approximate) thickness of the head gasket you can run more compression than 9.5. 10.25 would still be conservative and give more torque and power. If your piston is "down in the hole" then 9.5 or a little more is probably about right.
[Re: Airgrabber]
#274447
04/02/09 09:07 PM
04/02/09 09:07 PM
Mr.Yuck
Brookeville, Md
The 484 works well with your combo. Nice low end torque and power across the board.
mopar 484? that will be a dog w/ 3.23's it's not much different than the 509. It pulls terrible vacuum and has poor street manners. The old grind anyway.
[Re: Mr.Yuck]
#274448
04/02/09 09:44 PM
04/02/09 09:44 PM
Posts: 1,261 ILL
mark7171
ILL
the 484 is gonna want gear. It is a racing cam.
not as bad as the 509. Which is a serious cam that is every bit as good as the cams today. Most modern cams are small base circle. If a thumping shaft is getting shoved in a mill hole, It better be thick and bumpy.
