shift selector indicator #2742451
02/12/20 11:19 PM
02/12/20 11:19 PM
NC
P
psg Offline OP
psg  Offline OP
P
NC
I have an '86 D-150 automatic 360. The shift selector indicator is off about 3 letters. Is there a procedure or tech article about the process of resetting it?
Faith in every footstep, faith in every mile
Re: shift selector indicator [Re: psg] #2742453
02/12/20 11:29 PM
02/12/20 11:29 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
if you don't have a service manual,get one. it is your best friend. other than that, drop the trim part that the fuse box clips to and then drop the part under the steering column. move the shift lever and watch the cable move. bend the tab very carefully and you should be able to bring it back around to correct position.
Re: shift selector indicator [Re: rbkt65] #2742462
02/13/20 12:20 AM
02/13/20 12:20 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds like the wire for the indicator has slipped of a pivot point.
Re: shift selector indicator [Re: stumpy] #2742484
02/13/20 02:18 AM
02/13/20 02:18 AM
Guitar Jones Offline
Procedure or tech article?!? Bwahahaha. Sorry, once you see what that is you'll be laughing too. laugh2
