Re: External Oiling
[Re: maximus]
#274106
04/02/09 12:35 AM
04/02/09 12:35 AM
Posts: 10,216 Someplace you aren't
SomeCarGuy
You can get the kit from Milodon and a pan from them that will work out of the box. Or you can punch a hole in one you already have.
If you are running stock engine mounts IE not a motor plate, count on doing some work on building a hose that will fit. It isn't a hard task, just takes some time and paitence
I want my fair share
Re: External Oiling
[Re: SomeCarGuy]
#274107
04/02/09 10:33 AM
04/02/09 10:33 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Do you mean a dry sump system? where you can run a small pan? Or a wet sump with an external line. They are NOT anything close to each other.
Re: External Oiling
[Re: maximus]
#274109
04/02/09 12:13 PM
04/02/09 12:13 PM
moper
Columbia, CT
reason I ask is 3-4 quarts in a wet sump is not going to be safe.
