Re: Can't shorten aluminum driveshaft? [Re: G_bob] #273969
04/02/09 02:02 AM
04/02/09 02:02 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
I can't believe that your midplate added so much extra length to the assembly that now the driveshaft is to long.Is it truly binding or are you just worried about it binding? Give the measurements. Do you have 3/4" clearence with the car down on the ground? I would like to know this info. BTW they are full of it, I am positive you can weld it multiple times.
Post deleted by Defbob [Re: wheelsup68dart] #273970
04/02/09 02:10 AM
04/02/09 02:10 AM
Re: Can't shorten aluminum driveshaft? #273971
04/02/09 08:10 AM
04/02/09 08:10 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Cutting the spline will do no good since it doesn't bottom out in the trans.If your a ladder bar car can you adjust the bar lenght to get the distance or if your running springs put a spacer between the front spring perch and the body.We have shortened aluminum shafts before with no problems.We chuck the shaft in a lathe and turn off most all the old weld,cut the correct length and re-weld.
Re: Can't shorten aluminum driveshaft? [Re: B G Racing] #273972
04/02/09 08:21 AM
04/02/09 08:21 AM
Out West
408strokerdart Offline OP
Out West
The length of the drive shaft is not my only problem. I have also changed engine combinations and the new engine will put out 100+ more hp and the shaft is only a 3 1/4" dia shaft. Nobody I have talked to recommends it for my application that I have now. This is the reason behind my switch from wanting to shorten it to just replacement. If the car was lighter I could get away with it. Everyones comments tell me that they were simply full of it though.
Re: Can't shorten aluminum driveshaft? [Re: 408strokerdart] #273973
04/02/09 08:50 AM
04/02/09 08:50 AM
Columbus, OH
Ben Holt Offline
Ben Holt  Offline
Columbus, OH
Who did you talk to at MW? Travis is always a big help to me over there.... I am surprised that's what they told you, but they also may not like the 3 1/4" shaft. Everything we use from them in AL is 4". Just a thought
Re: Can't shorten aluminum driveshaft? [Re: 408strokerdart] #273974
04/02/09 08:51 AM
04/02/09 08:51 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I must have misunderstood the question.What is the issue of application?I see many big tire,hi hp cars running a similar 3-1/2 aluminum shaft even a few at #3400?We also have many heavy duty,hi torque trucks in our construction fleet with aluminum and aluminum/composite shafts.
Re: Can't shorten aluminum driveshaft? [Re: Ben Holt] #273975
04/02/09 12:04 PM
04/02/09 12:04 PM
Out West
Out West
Ben,
It might have been Travis that I spoke to. I hadn't even mentioned that the shaft was 3 1/4" dia. before he told me that they can't shorten it. Nobody that I called recommended a driveshaft smaller than 3 1/2" and about half of them suggested 4". I want as small as possible though since I have little space in the tunnel with my tubular driveshaft loop.
Re: Can't shorten aluminum driveshaft? [Re: 408strokerdart] #273976
04/02/09 05:09 PM
04/02/09 05:09 PM
Haysville, Kansas
rdrmod6 Offline
rdrmod6  Offline
Haysville, Kansas
I thought that I would put in my 2 cents on the welding aluminum issue. 6061 t6 is heattreated and artificaly age hardend from my understanding this process will need to be redone. If this is not done you could, and proably will see a rreduction in service life due to cracking. If the original builder had the driveshaft heat treated and then sold them to the vendor the vendor would have to arrange for welding and heat treating and on a single piece this might cost more than you want to spend. just an idea
