8.8 axle swap in a 91 D150 #2738618
02/01/20 08:59 AM
02/01/20 08:59 AM
Freeport,IL
P
Poohbah Offline OP
Poohbah  Offline OP
P
Freeport,IL
Just looking for info on possible 8.8 axle swap from a mustang into a 91’ D150.
I searched but just came up with 8.8 vs 8 3/4 topic.
Thanks.
Re: 8.8 axle swap in a 91 D150 [Re: Poohbah] #2738620
02/01/20 09:17 AM
02/01/20 09:17 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am not of much help but you might look into the Ford Explorer, or maybe ford Expedition(wider) for a swap. Reason is most of them have a limit slip differential and 3.73 or 4.10 gears, as well as bigger and thicker axle tubes.
I put a 8.8 out of a 97 Explorer in my Jeep 14 or 15 years ago. One of the best things I have ever done for the jeep, the disc brakes were a huge improvement. The 8.8 is a good strong axle with tons of aftermarket parts.
68 Barracuda Formula S 340
Re: 8.8 axle swap in a 91 D150 [Re: Bad340fish] #2738647
02/01/20 10:34 AM
02/01/20 10:34 AM
Freeport,IL
P
Poohbah Offline OP
Poohbah  Offline OP
P
Freeport,IL
I saw mustang because I wanted the 4-link setup. I know I’m gonna have to weld up something for the mounts. That’s my thinking anyway.
Re: 8.8 axle swap in a 91 D150 [Re: Bad340fish] #2738860
02/01/20 11:17 PM
02/01/20 11:17 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I think the 8.8 Exploder axles have one tube and axle longer than the other? Not sure about the Extradition or the Rustang.
Re: 8.8 axle swap in a 91 D150 [Re: JDMopar] #2738894
02/02/20 07:35 AM
02/02/20 07:35 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
haha
Re: 8.8 axle swap in a 91 D150 [Re: JDMopar] #2738943
02/02/20 10:44 AM
02/02/20 10:44 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
They do, in my Jeep it was a non issue, not sure about other installs.
To the OP if you use a later mustang axle(94+ maybe) I believe they are 1" wider and have disc brakes.
Re: 8.8 axle swap in a 91 D150 [Re: Bad340fish] #2739189
02/02/20 09:53 PM
02/02/20 09:53 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
An 8.8 out of an Exployer (the disc brake rear ends are also 4 link) is probably pretty narrow for a D150 I would think. We put one in a 57 Dodge wagon, and had to get wheels with less the 3 1/2" back spacing or the tires would rub on the inner body. You may want to measure the spacing between the backing plates on your D 150 and take a tape measure along when you go to the yard. Gene
Re: 8.8 axle swap in a 91 D150 [Re: poorboy] #2739227
02/03/20 12:29 AM
02/03/20 12:29 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Moser changes axle tubes from long to short or short to long. Not a bad deal if you're anywhere close.
Re: 8.8 axle swap in a 91 D150 [Re: poorboy] #2739520
02/04/20 01:45 AM
02/04/20 01:45 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
I have seen plenty of Explorer axles that used leaf springs.
Re: 8.8 axle swap in a 91 D150 [Re: Jjs72D] #2739543
02/04/20 09:13 AM
02/04/20 09:13 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yes mine had leafs on it. They went to independent rear suspension in like 03 or so.
Re: 8.8 axle swap in a 91 D150 [Re: Bad340fish] #2739777
02/04/20 09:15 PM
02/04/20 09:15 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Expedition was a 4 link and disc brake. But a goofy metric lug pattern in the range of 5x5.5 inch. I think they're too wide though.
Angry white pureblood male
Re: 8.8 axle swap in a 91 D150 [Re: ruderunner] #2739855
02/05/20 08:22 AM
02/05/20 08:22 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I very well could be wrong but I believe the first generation of expedition was a solid rear axle.
Re: 8.8 axle swap in a 91 D150 [Re: Bad340fish] #2740280
02/06/20 11:41 AM
02/06/20 11:41 AM
scratchnfotraction Offline
a 94 jeep Cherokee xj shares the same 43" perch centers as does the trucks. IIRC it is the 10bolt 8 1/4
A-body 8 3/4 share the 43" perch centers and with large brake offset axle bolt right in on top of springs and will tuck a 12" rim 29x15x15 M/T in the fenders.
73-74 C-body 8 3/4 is same width as 72-93 truck housings and only needs perch moved.
72-74 4x4 truck same width & FYI** came with the large 5 on 5 wbs same as 85-93 trucks
(my 85 stepside with 74 W100 8 3/4 ran the 10"-4.5 BS rim 29x9.50x15 and was tight but just right at outer fender lip.
myself I tub the bed flush to frame rails, flip the shackle and mount axle on top of springs. gives a better street/drag truck stance, no wheel hop, handles much better, still haul a 440/727 in the back with out hitting the frame rails.
my 88 440 truck has a-body 8 3/4 12"-4.5" BS rim 29 x15x15 M/Ts tucked in the fenders.
my 85 stepside shackle flip/tubbs has a 67 C-body 8 3/4 = same as E-body 8 3/4 only had to move perches in 1.5" each side and tucks a 10"- 4.5 BS rim with a 29x9.50x15 mud tire. with plenty of room to fender lips. looks like the 12" M/T combo will fit
I did the measuring on the jeep xj 8 1/4 and it will bolt right under a truck and will tuck 10" rims easy maybe a set of 12" rims
I did install a 8.8 with 3.73 gears with disc brakes in a 68 dart. other than the conversion joint needed and some fab/welding work it fit and work ok for that customer.
jeep axle less work IMHO.
Re: 8.8 axle swap in a 91 D150 [Re: scratchnfotraction] #2740511
02/06/20 09:25 PM
02/06/20 09:25 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
I'm not a Ford guy, but it seems like the 8.8 axle was used in some of the Ford F150's back in the 1980's or 1990's. An axle from one of those trucks might be similar in width the the Dodge axle. It wouldn't shock me if the spring perches are close to being in the right place. The truck frame rails on some of the older trucks had similar spacing. I've heard that was done so aftermarket truck beds, like tool beds, could fit multiple trucks. Back MANY years ago, I saw a guy swap an axle into a Ford truck. The donor axle may have been from an International truck....Not 100% sure because the donor truck was not at his home. Anyway, the replacement axle (from another company) bolted up to the spring perches with NO changes. The brake lines, U-joint, etc. was different, so some fabrication was still required. Overall, it was a fairly easy swap. Both trucks were 8 lug, so the bolt pattern even matched.
I have heard of installing the Ford 9 inch truck axles into Dodge trucks. The 9 inch looks quite similar to the 8 3/4 Mopar axle.
If the OP is set on going with a 4 link, using an axle designed for a that would probably be considerably easier.
Re: 8.8 axle swap in a 91 D150 [Re: QuickDodge] #2740730
02/07/20 05:32 PM
02/07/20 05:32 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
They still use them today, although there have been changes to them over the years.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 8.8 axle swap in a 91 D150 [Re: Poohbah] #2741700
02/10/20 07:03 PM
02/10/20 07:03 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
When I was looking into doing a rear axle swap I found certain E350's had similar width, and the gears and disc brakes I wanted for my 74 D100. I would assume an E150 would be close to the same width.
