Re: weeping freeze plugs
[Re: Sport383]
#2738103
01/30/20 02:27 PM
01/30/20 02:27 PM
Posts: 3,390 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Brass or steel? How long have they been installed?
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Sport383]
#2738112
01/30/20 02:40 PM
01/30/20 02:40 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Blue Devil. It's a stop leak additive from your local parts store.
[Re: Sport383]
#2738141
01/30/20 04:27 PM
01/30/20 04:27 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
[quote=Sport383]I have three weeping freeze plugs on my 383 cylinder heads. I can replace two without removing the heads. They only weep when it is cold but seem to seal up when the engine warms up. is there a good leak stop additive on the market to use to seal up the one I can not replace? Advice, recommendations, and snide remarks welcome because they are out there. Thanks in advance. [/quote Do it now the right way,you will have to eventually do it anyway !
[Re: dOc !]
#2738172
01/30/20 06:24 PM
01/30/20 06:24 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Sounds like they are rusted. If so, you are pushing a rope with a sealant for long term fix. Sealant should work for a while but will start leaking again.
[Re: Sport383]
#2738253
01/30/20 10:03 PM
01/30/20 10:03 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
Alumaseal (SP?) It comes in a small tube, it is a powder. It works great, use all the tube and follow the directions
[Re: markz528]
#2738358
01/31/20 11:01 AM
01/31/20 11:01 AM
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Sounds like they are rusted. If so, you are pushing a rope with a sealant for long term fix. Sealant should work for a while but will start leaking again. Unfortunately I agree with this. Sealants may help for a while, but based on the length of time that they have been in there, it sounds like your steel plugs are on their way out. The problem with limping them along is that one day under pressure one may fail completely and leave you stranded (best case) or overheat your engine (worst case).
[Re: Neil]
#2738496
01/31/20 07:52 PM
01/31/20 07:52 PM
Posts: 20,660 in a cattle trailer down by th...
Guitar Jones
They are rusted. Best plan is pull the engine and replace them all then you are done with it.
[Re: topside]
#2738528
01/31/20 09:52 PM
01/31/20 09:52 PM
Posts: 3,379 KY USA
mopargem
KY USA
I really wouldn't want that time-bomb ticking away, worrying about it every time I take the car out. Do the right thing, pull it apart as needed, and give it the permanent repair. If the freeze plugs in the heads are going away, I'd also wonder about the ones in the block. Granted, it's a PITA, and I don't envy anyone with that problem.
If there's enough access to the rear ones in the car, maybe a right-angle drill would help. I'm thinking drill a hole that you can screw a fastener into and pry the plug out. Might as well split the transmission and get those on the back of the block as well
[Re: mopargem]
#2738537
01/31/20 10:10 PM
01/31/20 10:10 PM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
If there's enough access to the rear ones in the car, maybe a right-angle drill would help. I'm thinking drill a hole that you can screw a fastener into and pry the plug out. Might as well split the transmission and get those on the back of the block as well There are no freeze plugs on the front or rear of the block on big blocks, just the cam plug.
[Re: Sport383]
#2738578
01/31/20 11:55 PM
01/31/20 11:55 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
I have three weeping freeze plugs on my 383 cylinder heads. I can replace two without removing the heads. They only weep when it is cold but seem to seal up when the engine warms up. is there a good leak stop additive on the market to use to seal up the one I can not replace? Advice, recommendations, and snide remarks welcome because they are out there. Thanks in advance. If I was you I would pull the motor, knock out all of the plugs, then wash the 1-2" of dirt and rust out of the bottom of the block with a hose. That is what I see when I see cars that have sat a lot. You might want think new head gaskets if they are steel shim type, and the spring in the lower hose will also be rusty or gone. It does not take long once you decide to fix it right.
