weeping freeze plugs #2738100
01/30/20 02:10 PM
01/30/20 02:10 PM
Washington State
Sport383 Offline OP
Sport383  Offline OP
Washington State
I have three weeping freeze plugs on my 383 cylinder heads. I can replace two without removing the heads. They only weep when it is cold but seem to seal up when the engine warms up. is there a good leak stop additive on the market to use to seal up the one I can not replace? Advice, recommendations, and snide remarks welcome because they are out there. Thanks in advance.
Re: weeping freeze plugs [Re: Sport383] #2738103
01/30/20 02:27 PM
01/30/20 02:27 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Brass or steel? How long have they been installed?
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: weeping freeze plugs [Re: wingman] #2738107
01/30/20 02:34 PM
01/30/20 02:34 PM
Washington State
Sport383 Offline OP
Sport383  Offline OP
Washington State
Installed back in 85 and steel.
Re: weeping freeze plugs [Re: Sport383] #2738112
01/30/20 02:40 PM
01/30/20 02:40 PM
an8sec70cuda Offline
Blue Devil. It's a stop leak additive from your local parts store.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: weeping freeze plugs [Re: an8sec70cuda] #2738121
01/30/20 03:03 PM
01/30/20 03:03 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Prestone had a stop leak that was fiber particles that clung together at any holes. I t worked ok back when I used it.
Permatex hardening form-a-gasket wiped around the holes before they go in is great. You may be able to wipe a thin coating around the freeze plugs to seal them now???
Re: weeping freeze plugs [Re: Sport383] #2738141
01/30/20 04:27 PM
01/30/20 04:27 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
[quote=Sport383]I have three weeping freeze plugs on my 383 cylinder heads. I can replace two without removing the heads. They only weep when it is cold but seem to seal up when the engine warms up. is there a good leak stop additive on the market to use to seal up the one I can not replace? Advice, recommendations, and snide remarks welcome because they are out there. Thanks in advance.
[/quote
Do it now the right way,you will have to eventually do it anyway ! twocents
Re: weeping freeze plugs [Re: 62maxwgn] #2738169
01/30/20 06:14 PM
01/30/20 06:14 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Weeping .... crying whiney.. plugs ? .... find out scope what their issues are and speak softly and calmly to them ! pity
You welcomed SNIDE remarks ... xmaseek
Re: weeping freeze plugs [Re: dOc !] #2738172
01/30/20 06:24 PM
01/30/20 06:24 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Sounds like they are rusted. If so, you are pushing a rope with a sealant for long term fix. Sealant should work for a while but will start leaking again.
Re: weeping freeze plugs [Re: Sport383] #2738253
01/30/20 10:03 PM
01/30/20 10:03 PM
Alumaseal up (SP?)
It comes in a small tube, it is a powder. It works great, use all the tube and follow the directions scope
Re: weeping freeze plugs [Re: Cab_Burge] #2738340
01/31/20 10:17 AM
01/31/20 10:17 AM
God's Country Maryland
GODSCOUNTRY340 Offline
K-Seal, Walmart sells it.
Re: weeping freeze plugs [Re: markz528] #2738358
01/31/20 11:01 AM
01/31/20 11:01 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Unfortunately I agree with this. Sealants may help for a while, but based on the length of time that they have been in there, it sounds like your steel plugs are on their way out.
The problem with limping them along is that one day under pressure one may fail completely and leave you stranded (best case) or overheat your engine (worst case).
Re: weeping freeze plugs [Re: Cab_Burge] #2738399
01/31/20 12:52 PM
01/31/20 12:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by Cab_Burge
Alumaseal up (SP?)
iagree It's been my choice for over 40 years. beer
Re: weeping freeze plugs [Re: an8sec70cuda] #2738420
01/31/20 01:57 PM
01/31/20 01:57 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Got to be careful with that stuff on vehicles with cats. Used it trying to limp along a magnum engine with a bad head gasket. Didn't work sealing the gasket,but sealed up the cat converter very well.
Re: weeping freeze plugs [Re: mgoblue9798] #2738475
01/31/20 06:05 PM
01/31/20 06:05 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If they were not sealed up originally they would have leaked right away. If they have gone this long and are just now leaking then rust may be the culprit.
A guy on here used a large pony clamp to push the plugs in in the back of the heads without having to pull them.
Use the form-a-gasket hardening sealer on the holes before they go in. 100% sealed for life this way.
Re: weeping freeze plugs [Re: Neil] #2738496
01/31/20 07:52 PM
01/31/20 07:52 PM
Guitar Jones Offline
They are rusted. Best plan is pull the engine and replace them all then you are done with it.
Re: weeping freeze plugs [Re: Guitar Jones] #2738513
01/31/20 09:04 PM
01/31/20 09:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I really wouldn't want that time-bomb ticking away, worrying about it every time I take the car out.
Do the right thing, pull it apart as needed, and give it the permanent repair.
If the freeze plugs in the heads are going away, I'd also wonder about the ones in the block.
Granted, it's a PITA, and I don't envy anyone with that problem.
If there's enough access to the rear ones in the car, maybe a right-angle drill would help.
I'm thinking drill a hole that you can screw a fastener into and pry the plug out.
Re: weeping freeze plugs [Re: topside] #2738528
01/31/20 09:52 PM
01/31/20 09:52 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Might as well split the transmission and get those on the back of the block as well
Re: weeping freeze plugs [Re: topside] #2738532
01/31/20 10:03 PM
01/31/20 10:03 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Even if you can do the contortions to get them out, you still need room to clean the bores & install new plugs properly.
Pull the engine while it is cold out & there is time to get-er-done before warmer weather hits so you can drive it.
Re: weeping freeze plugs [Re: mopargem] #2738537
01/31/20 10:10 PM
01/31/20 10:10 PM
There are no freeze plugs on the front or rear of the block on big blocks, just the cam plug.
Re: weeping freeze plugs [Re: Sport383] #2738578
01/31/20 11:55 PM
01/31/20 11:55 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If I was you I would pull the motor, knock out all of the plugs, then wash the 1-2" of dirt and rust out of the bottom of the block with a hose. That is what I see when I see cars that have sat a lot. You might want think new head gaskets if they are steel shim type, and the spring in the lower hose will also be rusty or gone. It does not take long once you decide to fix it right.
