Preventing rust on chrome wheels #2737678
01/29/20 12:22 PM
01/29/20 12:22 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I am going to have to put one of my cars outside with a cover for the rest of the winter. It has chrome wheels on it so I would like to know if anyone has any suggestions on something I can apply to the wheels to keep them from rusting. I don't have any other tires/wheels to swap on the car so I'm hoping there is something that will work. The car won't be driven so salt is not an issue, just rain or snow. If it does snow, I will clean it off the wheels when the snow stops and I will dry them off after each rain. Suggestions?
Re: Preventing rust on chrome wheels [Re: 440mopar] #2737682
01/29/20 12:30 PM
01/29/20 12:30 PM
ohio
bbtrux Offline
bbtrux  Offline
ohio
.fluid film in a spray bomb.
Re: Preventing rust on chrome wheels [Re: bbtrux] #2737688
01/29/20 12:39 PM
01/29/20 12:39 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I've used the Krown stuff--it comes in an aerosol can, too.
Whatever you spray on there, make sure you clean it off your brakes (especially if they are discs) before you try to drive it.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Preventing rust on chrome wheels [Re: wingman] #2737714
01/29/20 01:33 PM
01/29/20 01:33 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
One winter, I had to put my open trailer outside my shop under a tarp; sprayed its chrome steel wheels with WD40.
Washed trailer & wheels in spring and they were fine.
Re: Preventing rust on chrome wheels [Re: topside] #2737730
01/29/20 02:10 PM
01/29/20 02:10 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I was thinking maybe WD-40 might be an option. Probably what I will try since I already have a can.
Re: Preventing rust on chrome wheels [Re: bbtrux] #2737780
01/29/20 03:45 PM
01/29/20 03:45 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I agree with Fluid Film. Wont wash off as easy, like WD40. Grab a can at Lowes.
Re: Preventing rust on chrome wheels [Re: topside] #2737854
01/29/20 08:23 PM
01/29/20 08:23 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
iagree wd/40 works fine
Plymouth Makes It!
Re: Preventing rust on chrome wheels [Re: 440mopar] #2738398
01/31/20 12:51 PM
01/31/20 12:51 PM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
Take care not to let your tires sit on the ground without some kind of barrier between the tire and the earth. I've used galvanized sheet metal, plastic sheets and concrete stepping stones.
Re: Preventing rust on chrome wheels [Re: jbc426] #2738408
01/31/20 01:08 PM
01/31/20 01:08 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Maybe get some of the tire covers you see people put on the RV and boat trailers to keep the sun from rotting the tires? Even some trash bags over the wheels would keep the water off. Not sure you'd want an air tight seal as it may trap humidity.
Re: Preventing rust on chrome wheels [Re: Neil] #2738626
02/01/20 09:37 AM
02/01/20 09:37 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Keep the WD40 off of the brake rotors yellow
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Preventing rust on chrome wheels [Re: wingman] #2738873
02/02/20 12:37 AM
02/02/20 12:37 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
The Krown stuff is like spraying vegetable oil on something. I had two cars done with Krown - after a short while, the stuff rinsed right off. It does not set-up any kind of film. Very unimpressed with Krown.
Re: Preventing rust on chrome wheels [Re: 440mopar] #2740773
02/07/20 08:20 PM
02/07/20 08:20 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Four concrete blocks, and take the wheels off. twocents
