Re: Preventing rust on chrome wheels
[Re: bbtrux]
#2737688
01/29/20 12:39 PM
01/29/20 12:39 PM
Posts: 3,376 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I've used the Krown stuff--it comes in an aerosol can, too.
Whatever you spray on there, make sure you clean it off your brakes (especially if they are discs) before you try to drive it.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: topside]
#2737730
01/29/20 02:10 PM
01/29/20 02:10 PM
Posts: 732 USA
440mopar
USA
One winter, I had to put my open trailer outside my shop under a tarp; sprayed its chrome steel wheels with WD40. Washed trailer & wheels in spring and they were fine. I was thinking maybe WD-40 might be an option. Probably what I will try since I already have a can.
[Re: bbtrux]
#2737780
01/29/20 03:45 PM
01/29/20 03:45 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
.fluid film in a spray bomb. I agree with Fluid Film. Wont wash off as easy, like WD40. Grab a can at Lowes.
[Re: topside]
#2737854
01/29/20 08:23 PM
01/29/20 08:23 PM
Posts: 5,308 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
One winter, I had to put my open trailer outside my shop under a tarp; sprayed its chrome steel wheels with WD40. Washed trailer & wheels in spring and they were fine. wd/40 works fine
Plymouth Makes It!
[Re: 440mopar]
#2738398
01/31/20 12:51 PM
01/31/20 12:51 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Take care not to let your tires sit on the ground without some kind of barrier between the tire and the earth. I've used galvanized sheet metal, plastic sheets and concrete stepping stones.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: wingman]
#2738873
02/02/20 12:37 AM
02/02/20 12:37 AM
Posts: 8,393 Highland, MI.
Sunroofcuda
Highland, MI.
Whatever you spray on there, make sure you clean it off your brakes (especially if they are discs) before you try to drive it. The Krown stuff is like spraying vegetable oil on something. I had two cars done with Krown - after a short while, the stuff rinsed right off. It does not set-up any kind of film. Very unimpressed with Krown.
