Electrical upgrades #2730943
01/07/20 10:19 PM
01/07/20 10:19 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Going to do the bypass of the bulkhead with a 10 gauge wire and fusible link.
I keep seeing conflicting info. on the best place to run the wire from the BAT terminal on the alternator.
Some say the relay, some say stud on the starter and some say the positive post on the battery. While I realize all those locations lead back to the battery, is there one location that is better than another?
'63 Dodge 330
11.19 @ 121 mph
Re: Electrical upgrades [Re: GY3] #2730963
01/07/20 11:12 PM
01/07/20 11:12 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I ran an 8 gauge to the stud on the starter relay, from the 130 amp alt, works great on my 68 Charger.
Re: Electrical upgrades [Re: CSK] #2730978
01/08/20 12:04 AM
01/08/20 12:04 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I'm assuming rear mount battery. If it doesn't need a legal, functional master switch, I would want to keep it short and run it to the closest terminal stud for the main battery cable - starter relay, junction block, etc. Not the starter to avoid clutter & hot pipes, not all the way to the trunk to avoid that long run (voltage drop). If it has a master switch that you want to work correctly - run it to the battery side stud on the switch or the battery itself and consider going up a size because of the distance.
Re: Electrical upgrades [Re: CMcAllister] #2730979
01/08/20 12:13 AM
01/08/20 12:13 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
No, battery is still up front in the stock location.
'63 Dodge 330
11.19 @ 121 mph
Re: Electrical upgrades [Re: GY3] #2730987
01/08/20 12:53 AM
01/08/20 12:53 AM
CA
crackedback Offline
crackedback  Offline
CA
When I do the wire arounds I sell, I do them to attach at the starter relay. Make sure the feed wire back to battery is in good shape.
Run min. 8ga wire and 12ga fusible link. The factory wire is 10ga IIRC.
Just my 2 cents
Re: Electrical upgrades [Re: crackedback] #2731048
01/08/20 11:27 AM
01/08/20 11:27 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I actually removed the terminals at the bulk head. That's where the problem is. Drill thru the bulkhead and run the 10 gauge right thru the holes previously occupied by terminals. Leave the wire a little long on the interior side before splicing to the dash harness. That way if you have to remove the harness there is enough length to resplice. I've run a 110 amp alternator in my Challenger this way 16 years with no issue.
Doug
Re: Electrical upgrades [Re: dvw] #2731072
01/08/20 12:40 PM
01/08/20 12:40 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Doug
That is probably the best way to do it right there!
I got rid of all the factory wiring except for lights and wipers, but if I had retained more I would do exactly what DVW said. I would feel better with a circuit breaker or a fuse than a fusable link though, that is just me.
68 Barracuda Formula S 340
Re: Electrical upgrades [Re: Bad340fish] #2731085
01/08/20 01:57 PM
01/08/20 01:57 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I prefer a fuse to a fusible link. Reliable circuit protection. A simple fuse replacement as opposed to a harness repair in the event of a problem. MIDI style fuses are available in the amp rating you desire.
I would also be inclined to cut and terminate the alternator power line to the battery terminal on the starter relay, and continue the run to the interior of the car from that point. Not remove the power feed through the dash, but give the alternator feed line a more direct path to the battery.
Re: Electrical upgrades [Re: CMcAllister] #2731159
01/08/20 04:36 PM
01/08/20 04:36 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
That's the plan!
'63 Dodge 330
11.19 @ 121 mph
Re: Electrical upgrades [Re: GY3] #2731268
01/08/20 09:58 PM
01/08/20 09:58 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Yo up
Did same mod to Dart couple years ago when switching to the Denso alternator. Couple key points to note as others posted: 1) Drill out the bulkhead connector and feed the new wires through (eliminates a known problem area) 2) Have a look at the below info regarding "remote voltage sensing" and "by-passing Amp Gauge"; in the case of the Dart installed a terminal post under dash and ran the sensing wire to this location (e.g. may be good to install near MSD box) so that the voltage is being monitored close to where you have the most concern it's maintained. 3) In regards to fuses I'm using blade type fuses (easy to replace/readily avail), but for your race application might want to go with the suggested MIDI.
Remote Voltage Sensing
By-Passing Amp Gauge
SIngle Wire vs. Three Wire
beer
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Electrical upgrades [Re: GY3] #2731272
01/08/20 10:06 PM
01/08/20 10:06 PM
I had the 10 gauge wire from my 100 Amp alternator on my bracket car melt after the timing light 12V feed wire I had clip onto the alternator output wire grounded out, it smoked that 10 gauge wire in a big hurry puke
I called Power Master about having them look at my alternator to see if it was hurt or not ( I ended up replacing the 10 wire with another one that size and ran the motor, the alternator is still putting out 14.5 V revved up above 1500 RPM up) and during that discussion the tech told me to use a #4 gauge wire, not a 10 gauge, to the battery, he also said to make sure and ground the alternator with a #4 wire to a threaded bolt hole in the block from the threaded ground hole from the alternator boss shock up
I'm planning on doing both of those changes this winter wrench up Along with several other changes to make the car faster and easier to race and make changes at the track luck wrench
Re: Electrical upgrades [Re: Cab_Burge] #2731290
01/08/20 11:33 PM
01/08/20 11:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Quote
shock That's used for battery cable on a lot of cars. Depending on the length of the run.
Re: Electrical upgrades [Re: Cab_Burge] #2731313
01/09/20 03:39 AM
01/09/20 03:39 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I ran a 6 gauge from my Alt to the Starter relay lug. All my battery cables are 2 gauge.
I am one of the 'Amp' meter by-passers.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Electrical upgrades [Re: B Dartman] #2731365
01/09/20 10:50 AM
01/09/20 10:50 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Originally Posted by B Dartman
Yo up
beer
Thanks, Bill!
'63 Dodge 330
11.19 @ 121 mph
Re: Electrical upgrades [Re: Dave_J] #2731379
01/09/20 11:41 AM
01/09/20 11:41 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i used 8ga on my truck, alt b+ runs to the lug on the relay, then from there i feed into the cab bypassing the bulkhead (coz it was melted at the terminals). used 12ga fusible wire as well.
ordered one of the repro Denso style alternators, just looking for 60amp output, the test sheet shows the alt puts out 120amps at 13.5V...hope my 8ga wire is ok.
Re: Electrical upgrades [Re: GY3] #2731382
01/09/20 11:51 AM
01/09/20 11:51 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
It depends on what is the most important equipment to feed in your setup and use.
For example, If the system has had additional electrical items added, such as electric fans, fuel pumps, EFI the situation is different.
Or for example if race will be run on battery power, or .. or ...
That would be fine in most cases. The fusible link protects against the battery burning up big wires if any of them are accidently grounded.
Keep in mind the battery was not really meant to power the car car after starting.
Under normal running conditions the alternator powers the car. That's why the alternator output stud "BATT" was wired to the main splice first on the older cars. In the mid-70s Chrysler started to split the power up on the engine side of the firewall, so there was no longer a single main splice. But the concept remains the same. Power comes from either the alternator or the battery. Whichever one has the higher voltage.
If the battery is being run down, then it will draw more current during recharge. Feeding the recharge direct may make sense, as it shortens the route and the connections.
Feeding the main splice from the alternator by routing to the battery first creates a longer path with more connections. But in some situations that may not be important.
Re: Electrical upgrades [Re: Mattax] #2731386
01/09/20 12:05 PM
01/09/20 12:05 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Basic Power Supply Scheme or Strategy.
There are two power sources, alternator and battery.
Each connects to the main power distribution point (or points).
The battery feed also serves as the recharge line.
No fusible link was provided on the alternator output because if there is a short to ground the alternator and engine will generally stop running.
Re: Electrical upgrades [Re: krautrock] #2731396
01/09/20 12:26 PM
01/09/20 12:26 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Actual output from battery or alternator depends on the load.
In other words, whatever items are using electricity are primary determiner.
The second determiner is the voltage at which the items get the power.
For example, if power is provided at 14 Volts while the engine is running.
Ignition and field need 4 amps (1960s ignition and alternator)
Headlamps and markers draw around 12 amps
So driving at night, the alternator output would be 16 amps.
The only danger of a high output capability is if the battery is run down.
Batteries will draw current for recharging in proportion to the charge state.
A fully discharged battery, offered power at 14 Volts, may try to draw 40, 50, 60 amps or more!
Most of the factory alternators in the 60s and even 70s couldn't provide that, at least at idle, so the system was somewhat self protecting.
Re: Electrical upgrades [Re: Mattax] #2731400
01/09/20 12:36 PM
01/09/20 12:36 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
ithe test sheet shows the alt puts out 120amps at 13.5V
PS. If the test was run at 14.5 Volts, max output would have been less than 120.
Its not major, but makes it harder to compare. 120 amps x 13.5 V = power. Then divide by 14.5 Volts to get the current and the new voltage.
Chrysler's factory specs were done at 15 Volts (see your shop manual), so the output current looks lower when compared to a test made at 13.5 Volts.
The shop manual test was also usually done at 1250 rpm, whereas the ratings are usually done at high rpm. Again making it hard to compare. Sometimes the FSM lists both, sometimes not.
Re: Electrical upgrades [Re: Mattax] #2731402
01/09/20 12:43 PM
01/09/20 12:43 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Very minimalist setup. Small electric supplemental fuel pump and small nitrous control board. other than that, it is similar to a factory 1963 setup. No stereo, electric fans, fuel injection, etc.
'63 Dodge 330
11.19 @ 121 mph
