Electrical upgrades
#2730943
01/07/20 10:19 PM
01/07/20 10:19 PM
Posts: 4,700 Wichita
GY3
Wichita
Going to do the bypass of the bulkhead with a 10 gauge wire and fusible link.
I keep seeing conflicting info. on the best place to run the wire from the BAT terminal on the alternator.
Some say the relay, some say stud on the starter and some say the positive post on the battery. While I realize all those locations lead back to the battery, is there one location that is better than another?
Re: Electrical upgrades
[Re: GY3]
#2730963
01/07/20 11:12 PM
01/07/20 11:12 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I ran an 8 gauge to the stud on the starter relay, from the 130 amp alt, works great on my 68 Charger.
[Re: CSK]
#2730978
01/08/20 12:04 AM
01/08/20 12:04 AM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'm assuming rear mount battery. If it doesn't need a legal, functional master switch, I would want to keep it short and run it to the closest terminal stud for the main battery cable - starter relay, junction block, etc. Not the starter to avoid clutter & hot pipes, not all the way to the trunk to avoid that long run (voltage drop). If it has a master switch that you want to work correctly - run it to the battery side stud on the switch or the battery itself and consider going up a size because of the distance.
[Re: CMcAllister]
#2730979
01/08/20 12:13 AM
01/08/20 12:13 AM
GY3
Wichita
I'm assuming rear mount battery. If it doesn't need a legal, functional master switch, I would want to keep it short and run it to the closest terminal stud for the main battery cable - starter relay, junction block, etc. Not the starter to avoid clutter & hot pipes, not all the way to the trunk to avoid that long run (voltage drop). If it has a master switch that you want to work correctly - run it to the battery side stud on the switch or the battery itself and consider going up a size because of the distance. No, battery is still up front in the stock location.
[Re: GY3]
#2730987
01/08/20 12:53 AM
01/08/20 12:53 AM
Posts: 2,080 CA
crackedback
CA
When I do the wire arounds I sell, I do them to attach at the starter relay. Make sure the feed wire back to battery is in good shape.
Run min. 8ga wire and 12ga fusible link. The factory wire is 10ga IIRC.
Just my 2 cents
[Re: dvw]
#2731072
01/08/20 12:40 PM
01/08/20 12:40 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I actually removed the terminals at the bulk head. That's where the problem is. Drill thru the bulkhead and run the 10 gauge right thru the holes previously occupied by terminals. Leave the wire a little long on the interior side before splicing to the dash harness. That way if you have to remove the harness there is enough length to resplice. I've run a 110 amp alternator in my Challenger this way 16 years with no issue. Doug That is probably the best way to do it right there! I got rid of all the factory wiring except for lights and wipers, but if I had retained more I would do exactly what DVW said. I would feel better with a circuit breaker or a fuse than a fusable link though, that is just me.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2731085
01/08/20 01:57 PM
01/08/20 01:57 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I prefer a fuse to a fusible link. Reliable circuit protection. A simple fuse replacement as opposed to a harness repair in the event of a problem. MIDI style fuses are available in the amp rating you desire.
I would also be inclined to cut and terminate the alternator power line to the battery terminal on the starter relay, and continue the run to the interior of the car from that point. Not remove the power feed through the dash, but give the alternator feed line a more direct path to the battery.
[Re: CMcAllister]
#2731159
01/08/20 04:36 PM
01/08/20 04:36 PM
GY3
Wichita
That's the plan!
[Re: GY3]
#2731272
01/08/20 10:06 PM
01/08/20 10:06 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2731290
01/08/20 11:33 PM
01/08/20 11:33 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
the tech told me to use a #4 gauge wire ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) That's used for battery cable on a lot of cars. Depending on the length of the run.
[Re: Cab_Burge]
#2731313
01/09/20 03:39 AM
01/09/20 03:39 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I ran a 6 gauge from my Alt to the Starter relay lug. All my battery cables are 2 gauge. I am one of the 'Amp' meter by-passers.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: B Dartman]
#2731365
01/09/20 10:50 AM
01/09/20 10:50 AM
GY3
Wichita
Yo Did same mod to Dart couple years ago when switching to the Denso alternator. Couple key points to note as others posted: 1) Drill out the bulkhead connector and feed the new wires through (eliminates a known problem area) 2) Have a look at the below info regarding "remote voltage sensing" and "by-passing Amp Gauge"; in the case of the Dart installed a terminal post under dash and ran the sensing wire to this location (e.g. may be good to install near MSD box) so that the voltage is being monitored close to where you have the most concern it's maintained. 3) In regards to fuses I'm using blade type fuses (easy to replace/readily avail), but for your race application might want to go with the suggested MIDI. Remote Voltage SensingBy-Passing Amp GaugeSIngle Wire vs. Three Wire Thanks, Bill!
[Re: GY3]
#2731382
01/09/20 11:51 AM
01/09/20 11:51 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
I keep seeing conflicting info. on the best place to run the wire from the BAT terminal on the alternator. It depends on what is the most important equipment to feed in your setup and use. For example, If the system has had additional electrical items added, such as electric fans, fuel pumps, EFI the situation is different. Or for example if race will be run on battery power, or .. or ... Going to do the bypass of the bulkhead with a 10 gauge wire and fusible link. That would be fine in most cases. The fusible link protects against the battery burning up big wires if any of them are accidently grounded. Keep in mind the battery was not really meant to power the car car after starting. Under normal running conditions the alternator powers the car. That's why the alternator output stud "BATT" was wired to the main splice first on the older cars. In the mid-70s Chrysler started to split the power up on the engine side of the firewall, so there was no longer a single main splice. But the concept remains the same. Power comes from either the alternator or the battery. Whichever one has the higher voltage. If the battery is being run down, then it will draw more current during recharge. Feeding the recharge direct may make sense, as it shortens the route and the connections. Feeding the main splice from the alternator by routing to the battery first creates a longer path with more connections. But in some situations that may not be important.
[Re: krautrock]
#2731396
01/09/20 12:26 PM
01/09/20 12:26 PM
Mattax
Phila. Pa.
i used 8ga on my truck, alt b+ runs to the lug on the relay, then from there i feed into the cab bypassing the bulkhead (coz it was melted at the terminals). used 12ga fusible wire as well. ordered one of the repro Denso style alternators, just looking for 60amp output, the test sheet shows the alt puts out 120amps at 13.5V...hope my 8ga wire is ok. Actual output from battery or alternator depends on the load. In other words, whatever items are using electricity are primary determiner. The second determiner is the voltage at which the items get the power. For example, if power is provided at 14 Volts while the engine is running. Ignition and field need 4 amps (1960s ignition and alternator) Headlamps and markers draw around 12 amps So driving at night, the alternator output would be 16 amps. The only danger of a high output capability is if the battery is run down. Batteries will draw current for recharging in proportion to the charge state. A fully discharged battery, offered power at 14 Volts, may try to draw 40, 50, 60 amps or more! Most of the factory alternators in the 60s and even 70s couldn't provide that, at least at idle, so the system was somewhat self protecting.
[Re: Mattax]
#2731400
01/09/20 12:36 PM
01/09/20 12:36 PM
Mattax
Phila. Pa.
ithe test sheet shows the alt puts out 120amps at 13.5V PS. If the test was run at 14.5 Volts, max output would have been less than 120. Its not major, but makes it harder to compare. 120 amps x 13.5 V = power. Then divide by 14.5 Volts to get the current and the new voltage. Chrysler's factory specs were done at 15 Volts (see your shop manual), so the output current looks lower when compared to a test made at 13.5 Volts. The shop manual test was also usually done at 1250 rpm, whereas the ratings are usually done at high rpm. Again making it hard to compare. Sometimes the FSM lists both, sometimes not.
[Re: Mattax]
#2731402
01/09/20 12:43 PM
01/09/20 12:43 PM
GY3
Wichita
I keep seeing conflicting info. on the best place to run the wire from the BAT terminal on the alternator. It depends on what is the most important equipment to feed in your setup and use. For example, If the system has had additional electrical items added, such as electric fans, fuel pumps, EFI the situation is different. Or for example if race will be run on battery power, or .. or ... Very minimalist setup. Small electric supplemental fuel pump and small nitrous control board. other than that, it is similar to a factory 1963 setup. No stereo, electric fans, fuel injection, etc.
