Ported Small block Aluminum heads. #2730652
01/06/20 09:45 PM
01/06/20 09:45 PM
Wi
Scat Offline OP
Scat  Offline OP
Wi
Finally getting around to redoing the long block on my Duster. Currently has Edelbrock muli port efi on a cammed 340. Going to swap to a bigger solid cam and toss in some aftermarket rods and bump the compression up to 11 to 1~.
Who has had good luck with what? I know anything that's box stock needs to be gone though to verify tolerances and such. Also who would be the best person to turn to for porting? I have seen a lot of shady deals on having heads and other stuff worked on as well that has made me leary.
73 Duster 340 a518 6pack
Re: Ported Small block Aluminum heads. [Re: Scat] #2730686
01/06/20 11:50 PM
01/06/20 11:50 PM
AndyF Online content
AndyF  Online Content
Call Brian at IMM and see what he has to say. Brian builds a lot of SB Mopar engines so just tell him how big your budget is and how much power you want to make and he'll tell what your options are.
Re: Ported Small block Aluminum heads. [Re: Scat] #2730721
01/07/20 09:10 AM
01/07/20 09:10 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Dwayne porter is the only guy I know you can trust for your porting. As far as your cam, I had a 340 with 12.5:1 pistons in it, I believe it was a true 12:1 motor, the cam I had in it was a Erson solid flat tappet 258/258-535/535-107. This was an awesome cam for that combo. I tried a couple other cams and was very disappointed. The Erson went back it. That cam pulled hard right to 7000rpm. I know your looking for roller, but just wanted to throw that out there if you decide on SFT. This combo used ported J heads at the time as well and was in front of a 4 speed. Hope this helps.
Re: Ported Small block Aluminum heads. [Re: mopar dave] #2730730
01/07/20 09:35 AM
01/07/20 09:35 AM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
There is also Shane Studley from Precision Cylinder Heads. He does alot of Super Stock and bracket car stuff.
Re: Ported Small block Aluminum heads. [Re: AndyF] #2730746
01/07/20 10:33 AM
01/07/20 10:33 AM
oregon
greendart408 Offline
oregon
I wouldn't do this imop, a lot of people like him, the last set of heads I was involved with came back to us from him hand ported were full of holes. If I wanted to poke holes in good heads I could have done it myself.
Re: Ported Small block Aluminum heads. [Re: Scat] #2730750
01/07/20 10:50 AM
01/07/20 10:50 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Trick Flow 190’s.
Have a shop you trust look them over, correct anything that may need a tweak....... bolt em on and go.
Re: Ported Small block Aluminum heads. [Re: fast68plymouth] #2730780
01/07/20 01:05 PM
01/07/20 01:05 PM
Washington
madscientist Offline
Washington
Originally Posted by fast68plymouth
Trick Flow 190’s.
THIS IS THE CORRECT ANSWER
Re: Ported Small block Aluminum heads. [Re: madscientist] #2730785
01/07/20 01:12 PM
01/07/20 01:12 PM
oregon
oregon
Trick Flow 190’s.
Agreed
Re: Ported Small block Aluminum heads. [Re: greendart408] #2730805
01/07/20 02:12 PM
01/07/20 02:12 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Trick Flow 190’s.
Agreed
Did Trick Flow release their Intake yet? can't seem to find it anywhere for sale.
Re: Ported Small block Aluminum heads. [Re: b1dartsport] #2730886
01/07/20 06:47 PM
01/07/20 06:47 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Trick Flow 190’s.
Agreed
Not as yet fro what I have seen, not sure as to what is the delay, they had a sample on display at SEMA 2018 from what I have seen, didn't see it at PRI 2018 when I was there. Was it on display at SEMA or PRI 2019?
Alan Jones
Re: Ported Small block Aluminum heads. [Re: LA360] #2730891
01/07/20 07:16 PM
01/07/20 07:16 PM
So. Burlington, Vt.
So. Burlington, Vt.
The ootb flow numbers for the cnc ported Speedmaster assembled heads are pretty weak until you get close to .600 lift.
The lifts on this test were .100-.700:
Re: Ported Small block Aluminum heads. [Re: fast68plymouth] #2730926
01/07/20 09:39 PM
01/07/20 09:39 PM
Wi
Scat Offline OP
Scat  Offline OP
Wi
I have honestly not seen much of the Trick Flows. With everything I've seen of them today it looks like I cant go wrong. Even though they come cnc ported has anyone truly opened them up yet with bigger valves and some hand porting? Intrested to see how far they can go.
Re: Ported Small block Aluminum heads. [Re: Scat] #2730936
01/07/20 10:12 PM
01/07/20 10:12 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I had the opportunity to finally get to touch a set during the Halloween Classic at Norwalk in October
I wish they would have had one intake and exhaust valve out of their sample head but they didn’t do my short fingers could only reach so far. They claim max cfm is 301 but that’s with a 2.02 valve. I’ve hit 315-318 out of my Edelbrock heads with a 2.08 valve so yes they can be improved in the right hands. He also said he he intake will be released soon. The exhaust side looks very nice on a TrickFlow Head.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ported Small block Aluminum heads. [Re: Scat] #2735165
01/21/20 04:54 AM
01/21/20 04:54 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
They flow as advertised up to .500 lift. After that they maxxed out around 280cfm. Advertized at 302cfm. With a 2.08 valve, removing .04 from common wall, raising the roof .150, and widending the comb chamber to 4.05 flow picked up 20/25 cfm through .500 lift, still maxxed out at 285cfm. Almost 225cfm at .300 lift. Exh picked up a couple % over advertized with no port work, just widening the chamber. Chamber is made to fit 318 bore at 3.95 as delivered. Valves I put in them are from trick flow for their ford head. Correct length but 5/16 stem, so guides had to be changed. 2.08 valve is 15 grams lighter than the 2.02 valves supplied in them. Hopefully have them on the engine and at the track in mid march
Re: Ported Small block Aluminum heads. [Re: qwkmopardan] #2736304
01/24/20 09:20 PM
01/24/20 09:20 PM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
Anyone on here a dealer for them? what are the costs?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Ported Small block Aluminum heads. [Re: Stroker Scamp] #2736510
01/25/20 02:31 PM
01/25/20 02:31 PM
Summit sells them scope
Re: Ported Small block Aluminum heads. [Re: Cab_Burge] #2736526
01/25/20 03:16 PM
01/25/20 03:16 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Doesn’t shruggy Juggy whistling do penguin too scope xmaseek
Re: Ported Small block Aluminum heads. [Re: dOoC] #2736650
01/25/20 09:18 PM
01/25/20 09:18 PM
I ha've no idea what Jegs sells, I don't buy from them shruggy
Re: Ported Small block Aluminum heads. [Re: greendart408] #2736657
01/25/20 09:51 PM
01/25/20 09:51 PM
eastern L.I. ,NYC
K
kingdragon Offline
kingdragon  Offline
K
eastern L.I. ,NYC
Brian at IMM took me for a ride too. Spent good good money on some magic heads of his. I guess he thought he was selling to some back yard bonehead. He sold me Slapped together slop that needed another $1000 to get right. FACTS
I only buy MADE IN USA.
