6.4 BGE bore size's #2730066
01/04/20 06:16 PM
01/04/20 06:16 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Anyone run a BGE at 4.125 bore? Seems from the sonic checks I've seen its not a problem.
Re: 6.4 BGE bore size's [Re: fbs63] #2730338
01/05/20 04:25 PM
01/05/20 04:25 PM
Dyno1 Offline
Dyno1  Offline
yes, I did one at 4.125. Made good power.
Re: 6.4 BGE bore size's [Re: Dyno1] #2730366
01/05/20 06:59 PM
01/05/20 06:59 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Cool! Thanks for the reply.
Re: 6.4 BGE bore size's [Re: fbs63] #2731700
01/10/20 11:30 AM
01/10/20 11:30 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
The 463 we are building for my 09 Ram is 4.165 bore BGE block, the thinnest part is #8 cylinder , towards the back of the block, it's .131 on the Non thrust side facing the back of the block, it's a NA build. the major thrusts all average .185. Ric has a pair of 454's (4.125X4.25) that has been running around Philly for 2 years now. #1 engine is fine ,3 trans and one front end later, it's still running strong. # 2 sits more than it's driven.
over the weekend I was over my friend Vince's shop they had 364 BGE (4.125X3.4)W305 Whipple , ThiTek heads running 28lbs of boost on the mustang dyno...supposedly that's been together for 3 years now.....best pull was 1550 thru a FTI power glide.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: 6.4 BGE bore size's [Re: Ray408G3Hemi] #2732011
01/10/20 11:39 PM
01/10/20 11:39 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Nice! Thanks for the info.
