keith black 383 pistons ? #2730172
01/05/20 03:49 AM
01/05/20 03:49 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
i see there are 3 part no. for the 383 keith black pistions i am looking at for a 383 build .
162
162 R
162 L
looks like 162 has one type of valve relief , and the 162 R & 162 L have another ?
why 2 diff types of same part no? R & L are right and left . why are these made in a right and left ?
also valve relief some places poasted as 5 cc and some say 8 cc ?
anyone ran into this ?
also is there a tech line phone no . i dont see a k b web sight ?
thank you !
162 L
Re: keith black 383 pistons ? [Re: calrobb2000] #2730175
01/05/20 03:57 AM
01/05/20 03:57 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Go look under United Piston Machine in Reno Nevada. They also make the ICON pistons you might want to look at as well.
Todd
Re: keith black 383 pistons ? [Re: calrobb2000] #2730190
01/05/20 08:56 AM
01/05/20 08:56 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Their catalog is on line.
Be sure to look at their Icon IC687/KTD
Re: keith black 383 pistons ? [Re: BSB67] #2730198
01/05/20 09:41 AM
01/05/20 09:41 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the pistons are lefts and rights to orientate them with the intake valve. some of the newer KB pistons don't have that. you can send an e-mail to them and they'll help with your questions.
Re: keith black 383 pistons ? [Re: calrobb2000] #2730205
01/05/20 09:54 AM
01/05/20 09:54 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
The ICON’s are very nice for the price. I found a set for my 511 for $500 shipped.
Re: keith black 383 pistons ? [Re: mopar dave] #2730223
01/05/20 11:12 AM
01/05/20 11:12 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
OP, In case you don't already have it: https://uempistons.com/
1-800-648-7970
Re: keith black 383 pistons ? [Re: DrCharles] #2730249
01/05/20 12:52 PM
01/05/20 12:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m not really a big fan of how that KB162 piston is configured.
Short compression height with huge valve pockets.
Tougher to get any quench/compression out of it.
Re: keith black 383 pistons ? [Re: fast68plymouth] #2730340
01/05/20 04:26 PM
01/05/20 04:26 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That's why the 687 is so much better.
Even with Diamonds new 383 piston, you'll have to work pretty hard to get to 10:1, like zero deck and 75 cc. Eddy's
Re: keith black 383 pistons ? [Re: BSB67] #2730342
01/05/20 04:46 PM
01/05/20 04:46 PM
So. Burlington, Vt.
So. Burlington, Vt.
That Icon number posted looks pretty appealing with the 4.5cc dome volume.
Re: keith black 383 pistons ? [Re: calrobb2000] #2730368
01/05/20 07:18 PM
01/05/20 07:18 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
check over on cnc motorsports, lowest price I could find. I use the IC837 forged piston. Now $524 a set.
Re: keith black 383 pistons ? [Re: mopar dave] #2730542
01/06/20 01:38 PM
01/06/20 01:38 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
some recommendations here but nobody has asked what heads? pump gas? what will the engine be used for?
Re: keith black 383 pistons ? [Re: lewtot184] #2730545
01/06/20 01:44 PM
01/06/20 01:44 PM
So. Burlington, Vt.
So. Burlington, Vt.
True....... but this is the Race section...... so I assumed it’s not a motor home or a tractor.
As with any other build....... have a good plan, do the research, and figure out what’s the best direction to take for your build.
Re: keith black 383 pistons ? [Re: fast68plymouth] #2731155
01/08/20 04:29 PM
01/08/20 04:29 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I like KB 400 it has small dome and I have it in .040 over version had to order and wait for that .
But make easy 10.2 to 1 compression with 84 cc Eddy head and .005 down in the hole deck height. With .039 to .040 1009 gasket.
Comp cam 275 hl
Rpm intake .
Cheap 1.75 headers.
Drives good in my dads 68 charger with 727 and 3.55 gear .
1969 Dodge Charger 1969 Dodge Superbee
Re: keith black 383 pistons ? [Re: cjs69mope] #2731193
01/08/20 06:28 PM
01/08/20 06:28 PM
So. Burlington, Vt.
So. Burlington, Vt.
This is an example of why it pays to do your homework...... and really be sure of what you’re buying.
The early version of the KB400 had a positive dome volume.
They changed it at some point, and the one listed in the 2016 catalog shows the dome volume as “0”.
I believe the dome got smaller and the valve pockets got bigger.
What that means is...... if you have the “0” dome volume version in your zero deck +.030 over 383 with a 1009 gasket and 84cc heads...... you don’t have a 10:1 motor.
It’s a 9.36:1 motor.
Even swapping out the KB’s for the Icon piston with the 4.5cc dome...... it still only gets you to 9.78:1.
Take the heads down to 82cc’s...... and then you’d be at 9.98:1.
