Re: keith black 383 pistons ?
[Re: DrCharles]
#2730249
01/05/20 12:52 PM
01/05/20 12:52 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’m not really a big fan of how that KB162 piston is configured.
Short compression height with huge valve pockets.
Tougher to get any quench/compression out of it.
[Re: fast68plymouth]
#2730340
01/05/20 04:26 PM
01/05/20 04:26 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Tougher to get any quench/compression out of it. That's why the 687 is so much better. Even with Diamonds new 383 piston, you'll have to work pretty hard to get to 10:1, like zero deck and 75 cc. Eddy's
[Re: BSB67]
#2730342
01/05/20 04:46 PM
01/05/20 04:46 PM
fast68plymouth
So. Burlington, Vt.
That Icon number posted looks pretty appealing with the 4.5cc dome volume.
[Re: lewtot184]
#2730545
01/06/20 01:44 PM
01/06/20 01:44 PM
fast68plymouth
So. Burlington, Vt.
True....... but this is the Race section...... so I assumed it’s not a motor home or a tractor.
As with any other build....... have a good plan, do the research, and figure out what’s the best direction to take for your build.
#2731155
01/08/20 04:29 PM
01/08/20 04:29 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
I like KB 400 it has small dome and I have it in .040 over version had to order and wait for that . But make easy 10.2 to 1 compression with 84 cc Eddy head and .005 down in the hole deck height. With .039 to .040 1009 gasket. Comp cam 275 hl Rpm intake . Cheap 1.75 headers. Drives good in my dads 68 charger with 727 and 3.55 gear .
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#2731193
01/08/20 06:28 PM
01/08/20 06:28 PM
fast68plymouth
So. Burlington, Vt.
This is an example of why it pays to do your homework...... and really be sure of what you’re buying.
The early version of the KB400 had a positive dome volume. They changed it at some point, and the one listed in the 2016 catalog shows the dome volume as “0”.
I believe the dome got smaller and the valve pockets got bigger.
What that means is...... if you have the “0” dome volume version in your zero deck +.030 over 383 with a 1009 gasket and 84cc heads...... you don’t have a 10:1 motor.
It’s a 9.36:1 motor.
Even swapping out the KB’s for the Icon piston with the 4.5cc dome...... it still only gets you to 9.78:1. Take the heads down to 82cc’s...... and then you’d be at 9.98:1.
