new bullet #2729942
01/04/20 12:27 PM
01/04/20 12:27 PM
hustlin hoosier Offline OP
Hustlin Hoosier's new bullet goes to the dyno on Monday!
Re: new bullet [Re: hustlin hoosier] #2729962
01/04/20 01:09 PM
01/04/20 01:09 PM
K
KOS Offline
KOS  Offline
K
wedge or hemi?
Re: new bullet [Re: KOS] #2730005
01/04/20 02:38 PM
01/04/20 02:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You coming back to NA10.5????
Re: new bullet [Re: Al_Alguire] #2730052
01/04/20 05:15 PM
01/04/20 05:15 PM
Wedge , hemi's just do not go fast. We are targeting DXP 235 and extreme street. It is the same motor we ran in 2016 with a lot more cam 1.086 lift, a better exhaust port, we are using Braswell carbs 2.300 throttle bore, 1.85 and 1.9 rocker ratio's, more duration on the cam.
Re: new bullet [Re: hustlin hoosier] #2730120
01/04/20 10:07 PM
01/04/20 10:07 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
did you ever run Shewanda?
Re: new bullet [Re: hustlin hoosier] #2730160
01/05/20 01:07 AM
01/05/20 01:07 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
About time my friend!!!
Good luck and hope you get the numbers you are looking for.
Re: new bullet [Re: max_maniac] #2730247
01/05/20 12:47 PM
01/05/20 12:47 PM
K
KOS Offline
KOS  Offline
K
Indy 600-13 Goodwin heads? lets here the numbers!!
Re: new bullet [Re: KOS] #2730329
01/05/20 04:08 PM
01/05/20 04:08 PM
565 inches very similar to our last motor. The heads were machined by Goodwin but it is a long from his head. the head was a team effort among several people. The biggest effort was probably from Russ at Indy cylinder for modifying the core boxes. No casting no heads. Goodwin had no input in the castings, and the start of this project. Chuck, Russ, Todd, and Myself had a lot of input in this project. I believe I have supplied every set of heads that have been machined.
The old engine made 1222 hp, hopefully the new engine will make 1240!
Re: new bullet [Re: hustlin hoosier] #2730442
01/06/20 12:31 AM
01/06/20 12:31 AM
'murica
misfired Offline
misfired  Offline
'murica
For the shoot out cuda or the original cuda? Should definitely be enough to mix it up in 235!
Re: new bullet [Re: hustlin hoosier] #2730452
01/06/20 03:44 AM
01/06/20 03:44 AM
Why do you want to run the small tire classes?
I'm assuming your going to use a 235x60x15, yes or no? If not what size tire are you going to race with confused
Re: new bullet [Re: misfired] #2730465
01/06/20 08:34 AM
01/06/20 08:34 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
My guess would be the mustang
Re: new bullet [Re: a493demon] #2730491
01/06/20 10:43 AM
01/06/20 10:43 AM
Mustang, Pro bracket drag radial in 235 and 275 pro in extreme street.
Re: new bullet [Re: hustlin hoosier] #2730499
01/06/20 11:17 AM
01/06/20 11:17 AM
Cab, when you only make 1240 hp or less the only way you can win is to do a better job racing than the competition. almost every car in the class makes more hp than we do. We live on weight breaks and being more efficient than the rest of the field.
The smaller the tire the closer we get.
Re: new bullet [Re: hustlin hoosier] #2730535
01/06/20 01:12 PM
01/06/20 01:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well was kinda hoping to see you come back to NA10.5 but I get it, tough crowd for sure and like every other class just keeps getting faster. Best of luck with the new fresh bullet.
Re: new bullet [Re: Al_Alguire] #2730610
01/06/20 07:27 PM
01/06/20 07:27 PM
Nobody has to worry about us for awhile it blew on the dyno!
Re: new bullet [Re: hustlin hoosier] #2730627
01/06/20 08:19 PM
01/06/20 08:19 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Sorry to read this.
Re: new bullet [Re: justinp61] #2730645
01/06/20 09:18 PM
01/06/20 09:18 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Just Dang !
Condolences.
Re: new bullet [Re: hustlin hoosier] #2730659
01/06/20 10:06 PM
01/06/20 10:06 PM
Farmington Hills, Mich
Chuck@Best_Machine Offline
The engine did not “ Blow Up” After warming it up we noticed it was cranking slow. We check the lash and noticed it had increased so we ended the session and pulled it off. We think it may have hurt some cam bearings due to the the big spring pressure, we will know more once we take it apart.
Re: new bullet [Re: Chuck@Best_Machine] #2730700
01/07/20 02:00 AM
01/07/20 02:00 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Well that sucks
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: new bullet [Re: poppaj] #2730727
01/07/20 09:22 AM
01/07/20 09:22 AM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
Hopefully just a minor set-back - at least it was caught before the crank bounced off the floor
