Re: new bullet
[Re: hustlin hoosier]
#2729962
01/04/20 01:09 PM
01/04/20 01:09 PM
KOS
Re: new bullet
[Re: KOS]
#2730005
01/04/20 02:38 PM
01/04/20 02:38 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
You coming back to NA10.5????
Re: new bullet
#2730160
01/05/20 01:07 AM
01/05/20 01:07 AM
Posts: 6,353 Aurora, Oh.
max_maniac
Aurora, Oh.
Hustlin Hoosier's new bullet goes to the dyno on Monday! About time my friend!!! Good luck and hope you get the numbers you are looking for.
Re: new bullet
[Re: KOS]
#2730329
01/05/20 04:08 PM
01/05/20 04:08 PM
hustlin hoosier
565 inches very similar to our last motor. The heads were machined by Goodwin but it is a long from his head. the head was a team effort among several people. The biggest effort was probably from Russ at Indy cylinder for modifying the core boxes. No casting no heads. Goodwin had no input in the castings, and the start of this project. Chuck, Russ, Todd, and Myself had a lot of input in this project. I believe I have supplied every set of heads that have been machined.
The old engine made 1222 hp, hopefully the new engine will make 1240!
Re: new bullet
#2730452
01/06/20 03:44 AM
01/06/20 03:44 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
Why do you want to run the small tire classes? I'm assuming your going to use a 235x60x15, yes or no? If not what size tire are you going to race with
Re: new bullet
#2730499
01/06/20 11:17 AM
01/06/20 11:17 AM
hustlin hoosier
Cab, when you only make 1240 hp or less the only way you can win is to do a better job racing than the competition. almost every car in the class makes more hp than we do. We live on weight breaks and being more efficient than the rest of the field.
The smaller the tire the closer we get.
Re: new bullet
#2730535
01/06/20 01:12 PM
01/06/20 01:12 PM
Al_Alguire
Las Vegas
Well was kinda hoping to see you come back to NA10.5 but I get it, tough crowd for sure and like every other class just keeps getting faster. Best of luck with the new fresh bullet.
Re: new bullet
#2730659
01/06/20 10:06 PM
01/06/20 10:06 PM
Posts: 970 Farmington Hills, Mich
Chuck@Best_Machine
Nobody has to worry about us for awhile it blew on the dyno! The engine did not “ Blow Up” After warming it up we noticed it was cranking slow. We check the lash and noticed it had increased so we ended the session and pulled it off. We think it may have hurt some cam bearings due to the the big spring pressure, we will know more once we take it apart.
