When did Chrysler switch to Cast Iron six pack manifolds? #2728364
12/30/19 06:07 PM
12/30/19 06:07 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
I have a six pack challenger built in November of 1969. Would my car come with an aluminum or cast iron manifold?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: RSI700VIPER] #2728392
12/30/19 08:16 PM
12/30/19 08:16 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I don't have the bulletins, but I would believe your car would have come with aluminum intake.
I think it was in Dec. or beginning of 70 for cast iron.
Ron
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: RSI700VIPER] #2728393
12/30/19 08:18 PM
12/30/19 08:18 PM
Kirkland, Washington
Pacnorthcuda Offline
I don’t thing there was a hard switch in terms of a date. I think SOME December 69 builds were AL, but most were Fe by then. A November build could have been either, but more were probably Fe.
I think the supply chain was mixed for awhile.
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: RSI700VIPER] #2728414
12/30/19 09:19 PM
12/30/19 09:19 PM
I had a V code 1970 Charger R/T 4 speed car bought new in Victorville, CA in November of 1969 by the original owner.
I ended up becoming the 3rd or 4th owner of it in 1the spring of 1989 with the car being bought taken apart and missing the original Dana 60, 4 speed console six pack set up and the original block, the original owner had the short block replaced in the early spring of 1970. It had a SPD of 10-28-1969 under warrenty for some unknown reason shruggy.
I ended buying a late production 1969 dana 60 out of a 1969 Charger R/T and I was lucky enough to buy two different 1970 cast iron six pack set ups, one with non CA six pack carbs for the manual trannies and one CA set up for the automatic CA cars.
One of the cast iron intakes had a casting date of 10-21-1969 and the other one had a casting date of 10-28-1969 so that makes me think that Mopar switch to the cast iron 6 pack intakes in the early production run of the 1970 cars shruggy IHTHs thumbs
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: Cab_Burge] #2728420
12/30/19 09:37 PM
12/30/19 09:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The story for decades is that Edelbrock couldn't keep up with A12 production even in '69...and more of those motors were planned for the '70 models.
Only '70 6-BBL car I knew back in the day (a buddy's GTX) was iron, but I don't know its SPD.
Maybe someone in the A12 Registry has a good idea of the date of the switch.
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: topside] #2728452
12/31/19 01:29 AM
12/31/19 01:29 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there is an "early" & a "late" cast iron 440+6 intake - casting number 2946275 VS. 2946276 (& then a third design with the same 2946276 part # on it between the carb mounts)
I've heard rumors about the first design being "porous" or some other casting flaw causing Chrysler to purchase every aluminum intake available at Edelbrock to keep the engine assembly line moving while the intake was being redesigned/reconfigured
the 1970 model year started production with the cast iron intake & in the time gap between "275" & "276" manifolds is where the aluminum manifolds are found during 1970 engine production
I've seen a number of November scheduled cars with aluminum intakes, but more importantly would be the engine assembly dates, when the engine was assembled at the Trenton engine plant
the first design "276" intake has a casting/parting line down the center of the manifold scope
who has access to a 1970 440+6 car with its original engine and an aluminum intake? what's the car's: assembly plant, SPD & engine assembly date?
moparts 2946275 intake 5-15-69 early.jpgmoparts 2946276-1970-440-3x2bbl-intake 10-22-69.jpgmoparts 2948276-1971-440-3x2bbl-intake.jpg
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: 6bblgt] #2728467
12/31/19 08:06 AM
12/31/19 08:06 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
As usual, Dan, you amaze me with information that I’ve never heard of and have pictures to prove it! My Superbird was build in Late Nov. I’ll look today at the assembly date of the block and casting info of the manifold. It’s cast iron but it’s the original one as far as I know. I bought it in 82 with 65,000 miles and the engine had never been apart.
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: fastmark] #2728479
12/31/19 09:23 AM
12/31/19 09:23 AM
NW New Jersey
NW New Jersey
iagree
Very informative. I'll have to check my assembly date. The engine is numbers matching and the manifold is aluminum, but I don't have a complete history of the car.
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: RSI700VIPER] #2728485
12/31/19 09:41 AM
12/31/19 09:41 AM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
anyone could have changed manifold .if you didn't buy car new you will never know.
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: sixbbl 69] #2728486
12/31/19 09:56 AM
12/31/19 09:56 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
One thing I would like to add to this, when I had a 70 440+6 Cuda it had an aluminum on it when I purchased but came with the car's original cast iron.
Wanting to put it back to as original as possible I re-installed the cast iron intake and it had a noticeable seat of the pants difference in performance.
Maybe the cast iron was a bit more restrictive???? But my hiney felt it!
Ron
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: RJS] #2728493
12/31/19 10:42 AM
12/31/19 10:42 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
What was the weight difference?
Thanks, Joe
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: jlatessa] #2728503
12/31/19 11:45 AM
12/31/19 11:45 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Again don't have specs but I think the cast iron is 45-50lbs.
Ron
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: RJS] #2728508
12/31/19 11:54 AM
12/31/19 11:54 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
The "heft-o-meter" says it feels like a Ford FE intake, ~ 80 lbs. vs. 25 ~ 30 for the aluminum? 2¢
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: RSI700VIPER] #2728510
12/31/19 12:06 PM
12/31/19 12:06 PM
central il.
second 70 Offline
second 70  Offline
central il.
When I bought my 70 V code Cuda in 74 it had the manifold changed to alum and the direct connection racing carbs. I also got the factory cast iron manifold and stock carbs that were taken off of it.
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: RJS] #2728511
12/31/19 12:10 PM
12/31/19 12:10 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Ron
So you are saying the aluminum Edelbrock noticeably performed better?
Question: the 340 6-packs. Was there both alum. & cast iron in those as well? I haven't lifted mine in a while, but I think it is iron. Now I'm curious.
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: Sunroofcuda] #2728529
12/31/19 12:49 PM
12/31/19 12:49 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
My Superbird has the original 276 CI Intake that was cast 10/23/69. My engine was assembled 11/5/69 and car was assembled 11/12/69
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: Sunroofcuda] #2728536
12/31/19 01:30 PM
12/31/19 01:30 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
aluminum only
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: 3hundred] #2728560
12/31/19 02:31 PM
12/31/19 02:31 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Found somebody weighed theirs, 41 lbs. Alum should be ~ 1/3 of that.
MANY years ago I saw that the FE Ford was 84 lbs. Sure felt about the same when lifted, guess the 84 was wrong?
'69 300 Convertible
'16 300 S Hemi
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: 3hundred] #2728575
12/31/19 03:15 PM
12/31/19 03:15 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The 41lbs above is way wrong.
Six barrel intake weights:
56 lbs for iron intake
17 lbs for aluminum intake
Thread about 6bbl intake dates
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1696762/1.html
Re: When did Chrysler switch to Cast Iron six pack manifolds? [Re: NANKET] #2728586
12/31/19 03:41 PM
12/31/19 03:41 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
from the other thread "NANKET"
Quote
I have one 2946276 dated 8-20-69
can you get pics of this casting number?
does anyone have an intake cast between Thursday 9/25/69 & Wednesday 10/22/69?
