more trans questions #272678
03/31/09 06:16 PM
03/31/09 06:16 PM
somewhereintheswampsofjersey
1swingin Offline OP
1swingin  Offline OP
ok. i got the 8 in. converter. 4800 stall. iam picking up the low ratio first gear tomorow. 1 more! i dont mind swapping converters but how much is 2 much 4 the street? i dont wanna cook the trans running the 8 in. now and then on the street. i have a pretty big cooler. should i add a fan 2 it? thanks?
"I aint here on buisness baby,Iam only here for fun"
Re: more trans questions [Re: 1swingin] #272679
03/31/09 09:37 PM
03/31/09 09:37 PM
NC
440Jim Offline
440Jim  Offline
NC
I would put a trans fluid temp gauge in the car and use it. Then you should be OK. But too much stall speed and to low of rpm will generate some heat.
